engine and sub removal
2 replies to this topic
#1 ministudio2
ministudio2
  • 188 posts
  • Local Club: none yet
Posted 17 May 2007 - 06:00 PM
ok im wanting to remove the subby and the engine i have already choped the front panals of but its not braced yet as i want them
of anyone got a good guide to removing the subby with engine cheers
#2 davexdavexdave
davexdavexdave
  • 650 posts
Posted 17 May 2007 - 07:11 PM
just undo the rear subby mounts, tear mounts if there still there, disconect the exhuast and the brake servo if you have one, the throttle cable, steerin wheel and finally the tower mounts and it will come right off. oh yeah and undo the front shocks
#3 Tom Booth
Tom Booth
  • 822 posts
  • Local Club: TurboMinis.co.uk
Posted 17 May 2007 - 07:44 PM
And fuel lines, heater piping, choke cable, main wire from the solenoid, brake lines will need to be disconected, I did mine just as the line goes down theres a connecter there where I unfastened mine. Clutch slave cylinder will need to be disconected, I removed the cylinder from the flywheel casing on the block, 2 bolts ontop 14mm and one further down lower then the cylinder, 10mm if I remember. Loosen the tower mounts, then just undo the floor mounts and ltake the tower moutns out with the engine supported/being held and wheeled out the way (Y)
