Calipers
12 replies to this topic
#1 Spannermonkey6464
Spannermonkey6464
  • 587 posts
Posted 17 May 2007 - 06:51 PM
Hi just a quick one, Brake calipers im looking to get the 4 pot vented calipers but are there any other claipers that have been used on minis from other car manufactures??
#2 vasi
vasi
  • 897 posts
  • Local Club: Minis 'n' Oatcakes
Posted 17 May 2007 - 07:41 PM
Vented calipers?
The fiesta brake conversion is popular, of which there has been much mention here on this forum.
#3 Retro_10s
Retro_10s
    Moderator
  • 10,186 posts
Posted 17 May 2007 - 08:22 PM
Iv'e seen honda civic brakes on a mini from the states but it's a big job.
Edited by Retro_10s, 17 May 2007 - 08:22 PM.
#4 Spannermonkey6464
Spannermonkey6464
  • 587 posts
Posted 17 May 2007 - 08:27 PM
yea vented discs, fiesta conversion humm would that be better than the metro turbo conversion?
#5 Retro_10s
Retro_10s
    Moderator
  • 10,186 posts
Posted 17 May 2007 - 08:30 PM
probably not i'd say, but it depends what pads you use etc. The fiesta route is really a way to ensure you can use a disc set-up with 10's, but it's a bonus that the discs and pads are way bigger than the cooper S set-up.
#6 vasi
vasi
  • 897 posts
Posted 17 May 2007 - 08:32 PM
The metro turbo conversion is generally considered to be a disappointing upgrade over 2pot 8.4's.
#7 Spannermonkey6464
Spannermonkey6464
  • 587 posts
Posted 17 May 2007 - 08:34 PM
right so the 4 pot vented metro conversion is worse than 2 pot cooper s conversion? is that what you mean?
#8 Retro_10s
Retro_10s
    Moderator
  • 10,186 posts
Posted 17 May 2007 - 08:37 PM
No,... the Cooper S set-up uses 7.5 discs. 8.4 is the standard disc size on minis.
#9 Spannermonkey6464
Spannermonkey6464
  • 587 posts
Posted 17 May 2007 - 08:42 PM
sorry retro i should have put in previous post i replied to Vasi, ok so 8.4 discs with 2 pot calipers is considered better than the metro 4 pot & vented dics
#10 vasi
vasi
  • 897 posts
Posted 17 May 2007 - 09:10 PM
Perhaps I should have clarified. If you already have 2pot / 8.4, it's not really worth changing them to 4pot-metro / 8.4's. Better to spend money on decent pads and discs.
#11 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 17 May 2007 - 10:03 PM
The vented 4 pots are better, but not enough to justify the time and money is the general opinion. to be honest Metro callipers are just not that good, the best bet is some custom alloy 4 pots designed for a Mini from KAD, Mini Spares or Mini Sport. KAD being the best of these. Vented discs is also a bit of a waste of time on a road Mini IMHO. The car just isn't that heavy.
#12 milliemini
milliemini
  • 108 posts
  • Local Club: Bournemouth Mini Club
Posted 28 May 2007 - 12:56 PM
How do you know if you have 2 pot or 4 pot callipers?
#13 stef
stef
  • 799 posts
Posted 28 May 2007 - 01:28 PM
well if your car is standard you will have 2 pot calipers, this means one on each side.
4 pot means 2 on each side
2 + 2 is 4.
i just spent a large amount of money on brakes for my car, but only because i know there will be a bigger engine in there someday.
if your car is remaining largely standard, then there isnt much point. as has been said, get some new discs and better pads. you will notice the difference.
braided brake hoses helps too.
