i have got a pair of cv joints for a disc braked mini, how do you check if they are worn out off the car. im rebuilding the brakes for it and dont want to put knackered ones back on.
should they move freely or bit a bit stiff or what??
worn cv joints???
Nic
, May 18 2007 04:09 PM
3 replies to this topic
Posted 18 May 2007 - 04:09 PM
Posted 18 May 2007 - 04:22 PM
the simple answer here is you can't when there are off the car! unless the iner cage is flopping around? they should be nice and stiff
Edited by Matrix, 18 May 2007 - 04:23 PM.
Posted 18 May 2007 - 10:52 PM
If you insert a driveshaft with the spring clip removed, and attempt to twist the inner cage with that shaft against the stub axle of the CV, there should be no slack.
As Matrix states they should also be stiff to move in a radial manner. Any doubts, fit new / recon ones.
Posted 18 May 2007 - 11:32 PM
They are not to bad to do when they are on the car so take the gamble, i would you could save yourself
some dosh if they are OK.
