Hif 38
2 replies to this topic
#1 Rennsessel
Rennsessel
    Just On Tickover
  • 5 posts
Posted 18 May 2007 - 05:59 PM
Hello my name is Tom i´m from Germany.
I've got a problem with my Hif 38 on my 1000ccm Mini Cooper Mk IV. It has standard setup and an AAC needle. The Problem is that i'm loosing the power over 110 km/h or over 3000-4000 rpm do you know what this could be???
Tom
#2 stickycreambun
stickycreambun
  • 1,865 posts
Posted 18 May 2007 - 08:14 PM
hello Tom from Germany.
why you saying its your HIF38 causing your problem, unless there is a reason it could be about 432423648754219479214 different reasons un-related to the carb??
and also, is your car an export? I didnt know there was a mk4 998 cooper, maybe im just very wrong... :w00t:
#3 Rennsessel
Rennsessel
    Just On Tickover
  • 5 posts
Posted 19 May 2007 - 04:30 PM
i think it is the carb because i changed it (befor hs2) and i adjusted everything (ignition...) I need Help!!!!!!!
P.S. The Mini is build in 1986 and is an 998ccm so it its MkIV or am I wrong?
