OIL Questions
13 replies to this topic
#1 muddybuggies-com
muddybuggies-com
  • 97 posts
  • Local Club: MuddyBuggies Owners Club
Posted 18 May 2007 - 06:54 PM
I have a feeling that mayme possibly I drivce my buggy harder than normal and well every gear I take to around 6500 rpm I know its bad and its a lot of revs but I cant seem to help it.
I have been to the docs about my heavy foot he says nothing he can do.
So my problem is I think I need to upgrade my oil i use to suit my enthusiastic driving style.
Any suggestions? Ideas.
I am using commas 20w50 and I am getting a little bit of noise from the clutch bearings now :w00t: only on tickover, well to be honest I cant hear them when I am in any other gear....lol
SO please any help would be much appreciated
Danny
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 18 May 2007 - 07:07 PM
No, we are not having this thread again.
Search instead please, this particular subject always goes on for weeks. Along the way it generally causes upset and unrest and everybody ends up hating each other.
I'm going to keep an eye on this thread for a few days and the second it gets nasty and people start attacking each other I'm locking it.
#3 muddybuggies-com
muddybuggies-com
  • 97 posts
Posted 18 May 2007 - 07:37 PM
Oh dear,
How does it get nasty??
lol
Danny
#4 Big_Adam
Big_Adam
  • 7,435 posts
Posted 18 May 2007 - 07:41 PM
20/50 Unipart Green oil.
Many people have their own choices but I've found unipat stuff the easiest to get. Many people pref penitrat oil or duckam (that right?) oil for their mini's. I've found these hard to find localy and don't want to pay to post a large container of oil. Believe Slark used to race with the oil but oil is pretty much oil. Some of the flashier oil's for modern cars have lots of friction modifiers in and all sort which is all lovely but I still run my El Gordo on 20/50 unipart and I still drive regularly at 5000-6000rpm day to day. SO it will work fine.
If your getting noise from the clutch then thats a little weird as there isn't any oil there. The roller bearing in the end of the housing doesn't get it's own supply of oil.
edit
Everyone has their own opinions so evenong jumps in with the oil they believe to be best. All down to personal preference really.
Edited by Big_Adam, 18 May 2007 - 07:42 PM.
#5 muddybuggies-com
muddybuggies-com
  • 97 posts
Posted 18 May 2007 - 07:56 PM
When I say noisy, its like a rattle and then I press the clutch and it dissappears
Danny
#6 danwebster
danwebster
  • 637 posts
Posted 18 May 2007 - 08:14 PM
Sounds like the clutch release bearing is on its way out, cost a few quid to replace and has nothing to do with the oil :w00t:
#7 muddybuggies-com
muddybuggies-com
  • 97 posts
Posted 18 May 2007 - 10:29 PM
How easy is it to do? the clutch is not that old.
CHeers
Danny
#8 Monkeh
Monkeh
  • 159 posts
Posted 18 May 2007 - 10:52 PM
wouldnt it be one of the gearbox bearings if it dissapears when you push the clutch.
#9 minislapper
minislapper
  • 1,957 posts
Posted 18 May 2007 - 11:01 PM
No, it's likely to be what Dan has said above.
#10 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 18 May 2007 - 11:14 PM
yup more than likely the release bearing...but if you've been ragging the tits off it then it could be the idler about to shat itself, doubtful, but possible.
#11 jonny d
jonny d
  • 1,148 posts
Posted 18 May 2007 - 11:17 PM
It wouldn't be the release bearing as that only spins when the clutch is down it could just be the layshaft
chattering i think correct me if i' wrong someone.
#12 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 19 May 2007 - 12:17 AM
Dan Webster is right. Either that or the idler thrust clearance is out. Very common.
#13 Grayedout
Grayedout
  • 901 posts
Posted 19 May 2007 - 06:19 AM
As long as its adjusted correctly....if its not and the release bearing is constantly touching the pressure plate and running at engine speeds then it will soon wear it out !
#14 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 19 May 2007 - 06:59 AM
My take would be, if the noise goes away when you press the clutch, then it's more likely to be the idler bearing... especially when stationary...
If the CRB was colapsing, I'd expect a 'running' noise when the clutch is pressed, however checking the CRB is a lot easier than checking the idler
