Bizarre diff.
11 replies to this topic
#1 london1380
london1380
  • 11 posts
Posted 19 May 2007 - 10:46 PM
What's going on here? I can understand why you might want to weld up the diff but why machine off a shaft?Attached File  P1000173_copy.jpg   538.53K   69 downloads
#2 tino
tino
  • 805 posts
Posted 20 May 2007 - 12:09 AM
You want to go round in circles?
I have no idea.
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 20 May 2007 - 05:47 AM
It's been welded up for a start which means the output shaft will always turn... why it only has the one output shaft I dont know but all the power will be delivered to whatever's connected to it..
The only thing whic comes to mind is running the car on 2 wheels, russ swift stylee
unless of course the shaft hasn't been machined off and it's snapped ??
#4 icklemini
icklemini
  • 2,982 posts
Posted 20 May 2007 - 08:51 PM
would suggest that the shaft has broke - probably because of 'windup' due to the fact the diff is welded up.
ttfn,
Dave
#5 AlexM
AlexM
  • 1,302 posts
  • Local Club: NMOC, ECMC
Posted 20 May 2007 - 11:24 PM
ttfn,
Dave
whats windup?
#6 GiroUnit
GiroUnit
  • 437 posts
  • Local Club: Standlake!
Posted 20 May 2007 - 11:41 PM
id say its from a short circuit racer.. mini stox or hot rod like mine where we pretty much all run locked diff's.. cant think of any other reason you would want to lock a diff unless you want arms like popeye! and its just snapped the shaft clean off.. seen it happen a few times with a locked diff.. once when it was being loaded onto the trailer :thumbsup:
Edited by GiroUnit, 20 May 2007 - 11:44 PM.
#7 Matrix
Matrix
  • 589 posts
Posted 21 May 2007 - 10:35 AM
Seen some thing simalar once before...it was fitted to a trike but instead off running with drive shaft's it had a sprock and chain fitted. Odd way of doing it but maybe the reson? duno?????
#8 london1380
london1380
  • 11 posts
Posted 21 May 2007 - 11:59 AM
I think GW and Giro are probably right - it is snapped. Better angle in the photo below. It came from a gearbox that came with a new engine I bought to put in my car. I was told the box was a standard one from a metro so I was expecting a 3.1 or 3.4 FD and turned out to have a 3.7 and welded/broken diff! Not that I mind the 3.7 particularly - it'll be fun at least!
Suppose I should check the rest of the box over - but don't really know where to start looking. Any tell-tales apart from a broken diff that would indicate it's fubar'd?
Attached File  P1000174_copy.jpg   472.17K   25 downloads
#9 SQUADDIE
SQUADDIE
  • 51 posts
  • Local Club: N/A
Posted 21 May 2007 - 12:03 PM
Hi, sometimes you use a diff like that for dyno work, and swap the diff from box to box if that makes any sence.We wielded the diffs up when I work at Longbridge, mini plus Pg1 gearboxes just for the power take off to the dyno, as you only need the one shaft plus the diff locked, to turn it over.
#10 Woody
Woody
    Ring Runner 2005
  • 1,763 posts
Posted 21 May 2007 - 05:13 PM
There was a motor bike that used a mini engine mounted north/south with the diff welded up and one drive shaft to the back wheel
#11 icklemini
icklemini
  • 2,982 posts
Posted 21 May 2007 - 10:25 PM
whats windup?
whats happens when the diffs and such are locked (4 wheel drives without a centre diff too)
- the differencies in the rotation means that the transmission 'winds up', and somethings gotta give, at best it could be that the tyres slip, at worst: things start breaking...
with the one in the pic, cant see why you would want to machine one output shaft down to make it a 'single output' setup... could just fit the one output and with the welded up diff still have the same outcome.
or indeed, fit both outputs, and with the welded up diff, they would both turn anyway :s
hth,
Dave
#12 GraemeC
GraemeC
  • 7,472 posts
Posted 22 May 2007 - 09:13 AM
That last photo does look more machined than a wind-up failure. Looks a very clean flat surface.
However, if that has been machined off then there is no way to fit a pot joint. And with no pot joint there is gaping hole in the diff side cover! I suppose a plate could be tig welded over the side cover but its a lot of work.
