Which rings do i need.
Posted 20 May 2007 - 05:44 PM
Posted 20 May 2007 - 08:31 PM
rings are about £40
http://www.minispare....aspx?pid=37813
or a complete set of new pistons and rings are about £80
http://www.minispare....aspx?pid=37942
hth,
Dave
Posted 20 May 2007 - 08:52 PM
Posted 20 May 2007 - 09:07 PM
if im buying new pistons, do you think i should go for a different more expensive brand, the car is going to be used on the road every day.
i would imagine its to late for that i am afraid...
the 21251 piston is very low compression, and to get the compression back up a wedge is often taken off the top of the block. this then means you cant (for example) fit a 21253 (a high compression piston) as it'll hang out the top of the block far to much...
ttfn,
Dave
Edited by icklemini, 20 May 2007 - 09:10 PM.
Posted 20 May 2007 - 10:23 PM
engine?
Posted 21 May 2007 - 10:29 PM
not in a mini - they are replacement however for low compression engines - marina vans vor example!Is 21251 pistons standard on factory 1275s
would lower the compression.and what would happen if you put them in a high compression
engine?
Posted 21 May 2007 - 10:54 PM
FROM BROWN BROTHERS THEY WERE 1.6MM SHORTER THAN THE MG METRO PISTONS I WAS REPLACING SO I TOOK 1.6MM OFF THE
BLOCK, DID I DO THE WRONG THING? THEY WERE THE SAME OTHER THAN THE 1.6MM IN HEIGHT I WAS TOLD. HEAD WAS SKIMMED
60THOU AFTER WORK ON THE HEARTS AND POLISHING AS WELL ( MG HEAD )
Posted 21 May 2007 - 10:58 PM
Posted 22 May 2007 - 07:49 PM
