Simple Security Idea - Chain and Padlock
Posted 25 November 2004 - 02:03 PM
I thought I'd share a simple security measure I learnt from my dad.
Living in London I wanted a visible and effective theft deterrent on my mini.
A simple and cheap option is to use a chain and padlock set. You simply attach and lock one end of the chain to the base of your front seat, and the other end then loops through your steering wheel and is padlocked on itself.
You can buy a plastic coated security chain from your local hardware store (like the bikers use).
I recommend a substantial circular padlock (advertised as pick-proof and largely indestructible) as the prime lock. The padlock for under the seat just needs to be good quality.
The chain stores under the front seat when driving, and is easy to pull out when you want to lock the car.
The idea is that most would be thieves come prepared to defeat a lot of the marketed steering wheel clamps etc, plus they're a pain to store etc. The chain would require a sizable pair of bolt-cutters to overcome, which I'm hoping most would-be thieves don't carry around as standard gear.
I realise it won't stop a determined thief, but then who would want to steal a mini, right? It's main purpose is to deter the joy-riders, kids and druggies who look for quick opportunities. ie, this sends a visible message to find the next car along that won't be such a pain to steal.
Hope this helps.... :cheese:
Cheers,
Posted 25 November 2004 - 07:13 PM
Posted 26 November 2004 - 10:13 AM
Posted 26 November 2004 - 10:53 AM
Posted 26 November 2004 - 10:45 PM
Posted 02 December 2004 - 08:26 PM
Can get a nightstick from Halfords for about £30 and you can't drive a mini with one of them on, because it hits the pillars and the seat unlike in other cars where you can still drive them!
Will deter %90 of thieves, but if you get some proffessionals they'll still get it. Or nick the battery.
Posted 02 December 2004 - 09:27 PM
Posted 02 December 2004 - 11:00 PM
Next up is a removable steering wheel.
Oh, and a new custom loom so I can fit a Cat 1 Alarm Immobiliser!
Posted 04 December 2004 - 10:24 AM
rob
Posted 04 December 2004 - 10:57 PM
Posted 05 December 2004 - 10:39 PM
sell the boss at work, so i'll get it on discount
Posted 06 December 2004 - 10:03 AM
where can you get them from?
Posted 07 December 2004 - 05:10 PM
but where are you going to store your steering wheel when you are walking round a supermarket - or town or somewhere similar, wont it be a bit big to be carrying around?
Posted 06 February 2005 - 05:03 AM
If you do that. Put the switch as far back as you can. make the cut in the ignition wire WELL away from the ignition barrel because if they see the brake in the wire. they will just hotwire it from before the break. :cheese:What im doing eventually is getting a toggle switch, finding the ignition wire and making the cable run back to somwhere in the car so when i leave i flick the switch and there will be no power to the ignition.
