how easy/hard would they be to fit on a scale of 1-10
how hard would this actually be???
Posted 22 May 2007 - 02:57 PM
Posted 22 May 2007 - 03:11 PM
quite easy.. wire them through a switch out of the fuse box...
or wire them through a switch through the ignition wire.. (then your battery wont go flat because you've left them on - did this with kats)
Posted 22 May 2007 - 03:17 PM
interior lights for footwells
how easy/hard would they be to fit on a scale of 1-10... my thoughts are that if a chav can do it, then my guess is I, or someone i can pursuade to fit them, will be able to???
Hey there. These would look sweet underneath the seats, think i might get some. But id wire them so that they lit up when the door opened. Grounding it is easy and you can just use the live at the switch that lights up the interior light. Its probably a 2..
Please note; My methods are rough and in previous occasions with electrics i have set my car on fire.
Posted 22 May 2007 - 03:21 PM
HA... hmmmm... thats what i wanted actually lol but i hadn't thought of putting them under the seats, supose it would then light up both front and back floor space = D tis a goood idea
Posted 22 May 2007 - 05:19 PM
Ant
Posted 22 May 2007 - 05:25 PM
Edited by Tomf, 22 May 2007 - 05:25 PM.
Posted 22 May 2007 - 06:12 PM
They are cold cathode neons, mainly used inside computer cases. I purchsed loads off ebuyer for less than 3 pounds a set last year.
Posted 22 May 2007 - 06:17 PM
i have loads of 12 V led's with holders... red ones for outside and white for footwells and under rear seats... and more for the boot and engine bay!!!!!
Posted 24 May 2007 - 12:14 PM
Edited by Jamier101, 16 November 2012 - 09:46 PM.
Posted 24 May 2007 - 12:16 PM
I did this to my Corsa once, I wanted them to come on when I opened the doors. There are loads of legal things to be thought about if you want to drive with them on.
yeah i don't want them on while i'm driving... just when the doors are open!!
Posted 24 May 2007 - 12:45 PM
they soon broke so i ripped them off and never spoke of neons again
i had a set underneath my motorbike, they are easy to fit except i found the wires were very short, so they had to be lengthened.
Posted 24 May 2007 - 12:59 PM
Posted 24 May 2007 - 01:11 PM
ooo thankies... = D will have a look when someone gets in who would know where it isIf you only want them on when the doors are open you will need to wire it into the interior light circuit, it shouldn't be too hard. Check it out in the Haynes manual, if I get a minute and my car comes back tonight I will take look.
Posted 24 May 2007 - 02:27 PM
but then thats me, someone clever should have a better idea.
