HOW DO I FIT TWIN CARBS???
4 replies to this topic
#1 colcooper
colcooper
  • 20 posts
Posted 22 May 2007 - 09:54 PM
:D
Hullo again, :w00t:
after feeling a small surge of newbie confidence(now gone),...........have just had a bit of a stumble trying to fit a set of twin 1 1/4s su carbs onto my 91 cooper?
have enclosed some images?
basically (laugh now please)...havnt got a clue about what pipe does what, and what i need to connect or join???? - have tried manuals and internet search but no joy(so im not just leaning on you all again)
thanx ............... :thumbsup:
#2 Big_Adam
Big_Adam
  • 7,435 posts
Posted 22 May 2007 - 10:27 PM
PIC 1 =
Pipes top left = breather and petrol pipe.
Pipe to right = heater pipe.
Pic 2 =
Petrol. Put a petrol feed (from pump) on the right pipe. As it will feed thro to the other carb. Then on the right hand pipe just connect direct to float with NO T-bit.
Incidently. I'll buy that T bit off you. My twins don't have a flow thro like on your left carb.
#3 colcooper
colcooper
  • 20 posts
Posted 22 May 2007 - 10:40 PM
cheers for that big adam, ill give u a shout once its sorted, ta
#4 Udo
Udo
  • 1,670 posts
Posted 22 May 2007 - 10:46 PM
Basically as Big Adam said
Pic 1 Top left is fuel just below is a breather pipe (think you should find somewhere on twin carbs to connect this upto)
Other is the heater pipe going into and out of a heated inlet manifold, remove these and connect them together basically, you may new a new length of pipe.
Pic 2
To me it looks like somebody has put the float bowl lids on the wrong carbs as the one on the left has 2 connections and the one on the right has 1 connection
I would swap them over then the fuel pipe comes from down the bulkhead into the right float bowl then off the 2nd connection to the left float bowl and as Adam says you wont need the T piece in the fuel pipe
Hope that makes sense
#5 colcooper
colcooper
  • 20 posts
Posted 22 May 2007 - 10:49 PM
cheers udo, you rock :thumbsup: :w00t:
