fuel pump
supermotolee
, May 22 2007 10:51 PM
7 replies to this topic
Posted 22 May 2007 - 10:51 PM
what are you guys with carbed R1 minis doing about fuel pumps is the origional R1 pump ok as it came with my engine or do you run a facet one or something? what pressure do the R1 carbs need to run properly?
thanks lee
thanks lee
Posted 25 August 2007 - 07:09 PM
this is done to stop fuel starvation on injection models because of shape of front tank,
im running injection, i run a facet at the front that pump low pressure / high volume to the rear ,
it then goes into a swirl pot. which when full goes back the front tank.
i then at the bottom of the swirl pot have a high pressure pump that goes to a t piece with a fuel regulater on it and one goes to the engine,
the pressure in the line stays at 43psi then. and over fuel goes back to the swirl pot ,
might not help with yours but might with other peoples.
Posted 25 August 2007 - 09:02 PM
For the carbs you only need 2 or 3 psi so the R1 pump should be fine, however i use a solid state pump (one of the lower capacity ones, cant remember which) set to 2 or 3 setting on the regulator, never had any problems!
I can check which pump i have if you really need to know...
Posted 25 August 2007 - 09:17 PM
i agree - definately the lower pressure, my dad had problems with flooding, he had a solid state but was not low enough, runs great with the even lower one now
adrian
Edited by adyzr1, 25 August 2007 - 09:18 PM.
Posted 25 August 2007 - 10:05 PM
Im having this exact problem at the minute. I bought the 5psi fuel point not realising it was only suposed to be 2.5 max! an new 1 is on order as we speak!
Posted 26 August 2007 - 09:32 AM
i'm running the std one mounted low in the boot it seems fine for general running and revving on the drive not taken the car out at any speed yet so i'l guess i'l find out if its emptying the float bowls, will most probably get it on a dyno asap so it can be checked in relative saftey...
Posted 26 August 2007 - 08:33 PM
Have you got a build diary going or any pics of the build as im really interested in this conversion.
Posted 28 August 2007 - 04:41 PM
no sorry i should do really but i havent taken many pictures there is a few on www.pro-motive.com
