should the stray wire on the right to the coil be connected? its black and white. when the ignition is on the coil gets really hot. i take it this is the problem?
Edited by mikecmini, 23 May 2007 - 09:26 PM.
Posted 23 May 2007 - 09:25 PM
Posted 23 May 2007 - 09:42 PM
Posted 23 May 2007 - 10:02 PM
Posted 24 May 2007 - 07:07 PM
Posted 24 May 2007 - 07:34 PM
Posted 24 May 2007 - 07:38 PM
the black and red wire are from electronic ingnition that has replaced the points.No it is not, if you earth the coil negative directly the ignition will not work. It is either the tacho sensing wire or the original dizzy connection (which looks to have been replaced with a plain black wire in your car).
You also seem to have a plain red wire supplying the coil as well as the yellow/white cranking bypass. Something funny is going on there.
Do you have electrical transformers in your home? That turn 240 volts into 6 or so for charging phones for example? Do you expect them to run warm or hot? The coil is a transformer, converting 12v into roughly 30,000 volts. Do you think it might get hot doing that?
