Building a 1330 engine
1 reply to this topic
#1 ChrisL
ChrisL
  • 157 posts
Posted 24 May 2007 - 12:32 PM
I'm starting to rebuild my 1330 motor. My question is do I need a breather on the timing chain cover and the clutch housing.
The gearbox is from a 998 so doesn't have one.
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 24 May 2007 - 06:10 PM
Frankly, yes. If you don't vent the crankcase you'll get a sluggish engine, plenty of oil leaks and nasty crud building up inside the engine. You need to ventilate it and ideally build a positive crankcase ventilation system to actively draw out and burn off the fumes collecting in the crankcase.
