Clutch and flywheel removal
8 replies to this topic
#1 chris_ba1212
chris_ba1212
  • 19 posts
  • Local Club: Abingdon Mini
Posted 26 May 2007 - 10:32 PM
I have searched and found a few helpful tips but all to no avail. I bought one puller a universial so not that great and it died under the pressure. Now have another but am still unable to remove the bloody thing!
It's on a 998 engine 1991 the flywheel is loose behing the clutch and is wobbleing but i cannot remove the rest of it and am loosing faith.
Iv'e tightened it up as much as possible with 6 foot on breaker bar smaked it with big hammers nothing it doesn't move at all. Tommorrow the angle gringer is coming out and it will be removed that way if it has too.
All i need is the gear box and the bolts from the crank that drive it anybody with any advice or anybody wants to do it for me :blink: much appreciated thanks
#2 chairchild
chairchild
  • 606 posts
Posted 26 May 2007 - 10:45 PM
if it's a verto clutch, theres a chance that it may have welded itself to the crank - meaning it's going to be VERY difficult to remove it!
I'd say leave it on there for as long as possible, every day tightening it a bit more, and giving the centre bolt (nothing else) a nice big wallop with a hammer. It'll either come off, or shear something!
#3 chris_ba1212
chris_ba1212
  • 19 posts
Posted 26 May 2007 - 10:47 PM
it already has broken a socket ripped the threads off one puller i have never know anything like this ever i'm amased at how it's holding on
#4 AlexM
AlexM
  • 1,302 posts
  • Local Club: NMOC, ECMC
Posted 26 May 2007 - 10:53 PM
An oxyacetylene torch should get it off. You may have to pay an engineering shop to do it though.
#5 JD8891
JD8891
    Previously known as Soul_racer
  • 379 posts
Posted 26 May 2007 - 11:03 PM
Is it this job a bucket of hot water works for, or am i gettin mixed up? I know theres storys around of summit like this flying across the garage when hot water was poured on it?
JD
#6 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 27 May 2007 - 12:04 AM
Key plate definitely removed? Crank in removal position?
Leave something under it to catch it while leaving the breaker on it, they can damage themselves if they hit the floor.
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 27 May 2007 - 06:53 AM
An use a puller designed to pull the A series clutch and not a universal one....
#8 chris_ba1212
chris_ba1212
  • 19 posts
Posted 28 May 2007 - 09:32 AM
It's off!!!
It took a combination of methods in the end the last puller i used was for an A series engine with that nothing. So we heated it whith the puller still pulling still nothing. Then we were tapping from behing on the fly wheels while heating and pulling still nothing.
Out come Mr Grinder cut off a few chunks of metal close to the crank put the puller back on continued the leating and as we were chissiling away at it very close to the crank now it started to turn on the crank. Tightened the puller and it came off slowly. There was no Bang like described it came very very slowly bit by bit. But none the less it's off!
#9 TOMMO0302
TOMMO0302
  • 1,688 posts
Posted 28 May 2007 - 09:35 AM
nice one, its a great feeling when they come off especially when they have got the better of you for the past few days! :lol:
My last one didnt give up until i showed it the grinder either!
