nothing!
12 replies to this topic
#1 bigcon
bigcon
  • 57 posts
Posted 27 May 2007 - 09:29 AM
Problems!! My friend popped over yesterday in her mayfair and asked me to look at her clutch & gearbox linkage as she was finding it hard to locate gears, so being the dutiful budding doofus mechanic had a quick look and decided it needed more clutch fluid and a new slave cylinder reseal kit to start with. Anyways asked her to move the motor so i could get in the garage and hey presto not a sausage!! no light on the dash nothing, a couple of tries later and the car started but when she put it in reverse engine stalled again, so i quickly checked over the earth lead on the engine, heavens opened, i got wet, car stayed in front of garage, gave her a lift home, now its my problem!! Any ideas??
#2 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 27 May 2007 - 10:00 AM
Loose battery connection?
Dead battery? - jump start? bump start?
#3 rosewhite
rosewhite
  • 486 posts
  • Local Club: LSMOC
Posted 27 May 2007 - 11:06 AM
Double check the battery connections - even if they seem alright there could be something breaking the connection
#4 rosewhite
rosewhite
  • 486 posts
  • Local Club: LSMOC
Posted 27 May 2007 - 11:07 AM
#5 blacktulip
blacktulip
  • 6,231 posts
Posted 27 May 2007 - 11:13 AM
also check the starter solenoid and coil wiring for bad connections.
#6 bigcon
bigcon
  • 57 posts
Posted 27 May 2007 - 03:17 PM
cheers , i'll have a look once it stops raining!! As usual it seems to be pointing towards electrical!
#7 Mini Mad Rich
Mini Mad Rich
  • 760 posts
  • Local Club: Leamington Spa Mini Massive
Posted 27 May 2007 - 03:24 PM
I know this might sound stupid but you didnt leave the head lights or anything on at all?
I've done that in the past and found that to be the cause after 45 mins or so of fault dianosics :lol:
Rich
#8 bigcon
bigcon
  • 57 posts
Posted 27 May 2007 - 05:54 PM
Rich
nah no lights left on, it was only turned off for a matter of 5 mins whilst i had a quick butchers at it, haven't been out yet as it hasn't stopped p*ssing down all day!! ho hum happy holidays!!
#9 crum01
crum01
  • 115 posts
Posted 27 May 2007 - 06:09 PM
I had the same problem; would be fine one minute then no electrics at all, I checked all earths and battery connections, even bought a new battery. It turned out in the end to be a loose connection to the starter motor, since I found that everthing's been fine.
#10 busa1999
busa1999
  • 116 posts
Posted 28 May 2007 - 08:10 AM
also check the main battery lead under the car where it starts to go up into the engine bay my one looked like it had been cooked by the exhaust and had started shorting on the body quite common problem me thinks as i had a spare off a scrapped car and this was the same
#11 bigcon
bigcon
  • 57 posts
Posted 28 May 2007 - 08:11 AM
well i've sat and watched out the window for a couple of days, so time to dust off my speedo's and put my shower cap on me thinks and get amongst it!!
#12 minidan
minidan
  • 2,354 posts
  • Local Club: LSMOC
Posted 28 May 2007 - 11:59 AM
yeeea get stuck in.
and check that positive cable under the car
#13 bigcon
bigcon
  • 57 posts
Posted 02 June 2007 - 07:59 AM
Sorted!!! loose connections on the starter solenoid!! bit of wire brushing, tighten up nut, start motor, send her on her way, cup of coffee, I thank you!!
