hi,
having just been faffing about getting the digital speedo working i have started the car up this morning and have got no tacho now. looking under the dash i have a spare wire comming out of the tacho with a connecter that has obviously pulled out from some where?? i can not find any other wires which this could connect to so i am wondering if it has been slotted in to a block connecter some where amongst the harness. if this is the case has any one any idea of which one it might be?
i dont want to just touch the wire to others randomly untill it works again incase i damage somthing.
the other two connected wires coming out off the tacho are black and red. the illumination also still works. bearing in mind its a after market tacho and the wiring harness has be chopped about a far bit.
cheers
tacho wiring
gixxerpower
, May 29 2007 11:43 AM
4 replies to this topic
Posted 29 May 2007 - 11:43 AM
Posted 29 May 2007 - 01:00 PM
Since this is an aftermarket tachometer, the sensing wire is probably "green" based on the other colors you mentioned. This green wire should be connected to what is probably a white/black wire somewhere behind your dash.
Just to be clear about the other tach wires, the black one should be earth/ground and the red one will go to a switched 12V power source. There's probably a white wire also and it needs to go to the dashboard lamp wiring.
Posted 29 May 2007 - 01:34 PM
cheers for that. yes the wire is greens that not connected. i assume the withe/balck one im looking for is to the coil then.
Posted 29 May 2007 - 04:17 PM
Hi. Yes, the white/black wire should go back to the coil and be connected to coil (-).
Posted 29 May 2007 - 09:01 PM
sorted. thanks for your help.
