1380 Offset Boring
Posted 30 May 2007 - 05:40 PM
I have spent two hours here now and still can't find the answer. My toying with Minis is some twenty years old, and I am just rebuilding a little pickup I found. Living in British Columbia info that used to readily available twenty years ago is hard to come by. And my memory isn't what it used to be.
I am looking for offset boring details. I have the Vizard book, and that makes reference to offsetting a smaller block. Do the same specs apply to a 1275? My question really is :
1. how much and which way to offset bore a 1275 block that cam eout of Mtro from what I understand to take the AE20659 73.5mm pistons.
2. Piston to wall clearance for the AE20659 pistons
Can anyone help please?
Posted 30 May 2007 - 05:48 PM
Posted 30 May 2007 - 09:40 PM
That last bit is usualy ommitted, but it gives a little more metal where the main oil gallery is.
As for piston clearance, either ask your machinist who is machining the bore or email/ phone AE. A standard clearance would most probibly be fine.
Posted 31 May 2007 - 02:41 PM
move cylinder 1/2 centers 10 thou away from the center of the block. Move cylinder centers 3/4 10 though the oposite way from the center of the block. Thereby increasing the cylinder centers between 1/4 and 2/3 by 20 thou. Move all cylinder centers 10 though towards the pushrod side of the engine.
Thanks a lot guys. That will do me.
