Please help me Fuel gauge troubles.
Posted 30 May 2007 - 08:04 PM
To check if the gauge even worked at all i put a 12v feed through it and the needle moved up as if to show that the tank is full.
So does anyone know what i have done wrong, i though that even if the sender wasnt correct for the gauge that it would at least move a bit.
Someone please help me.
Tom
Posted 30 May 2007 - 08:59 PM
Posted 30 May 2007 - 11:06 PM
Posted 30 May 2007 - 11:54 PM
Ebay link it says mini in the title but also says other cars...
Ebay link
Edited by Tomf, 31 May 2007 - 10:34 AM.
Posted 31 May 2007 - 02:22 AM
Quick question: When you were testing the fuel gauge portion of this 3-3/4" gauge, did the needle move quickly or did it slowly rise? If the needle can bounce around, and if the needle moves very quickly when you test the gauge, it isn't suitable for use with the late model sending unit.
The eBay links were for a fairly typical looking late model Smiths gauge. Those are bimetallic and respond slowly to changes at the sending unit. The basic hook up for this and other compatible gauges is: One spade (Lucar) connector on the gauge gets connected to the output of the voltage stabilizer ("I" terminal on the stabilizer). The other spade lug on the gauge goes off to the sending unit. The sending unit must have a good clean ground connection.
Posted 31 May 2007 - 06:56 AM
Mini fuel gauge senders (the bit in the tank) work by providing a resistive path to earth. The more fuel in the tank, the less resistance there is, so the fuel gauge registers higher.
By connecting the other terminal on the gauge to earth, you have essentailly connected both terminals to earth, so it won't work.
Once side of the gauge needs to be connected to the fuel sender on the tank, the other side needs a regulated supply (usually around 10v). You can buy a small regulator chip that does this if necessary. Type in smiths regulator on ebay and you should come across a bloke that sells these if you are unsure.
Not sure what the green and black wire is on the clocks, as i don't use Mini looms on any of my cars, but you can test it quite easily with a multimeter to see if it is the one from the sender.
Posted 31 May 2007 - 10:00 AM
Posted 31 May 2007 - 10:17 AM
Also when i plugged the 12V feed in with an earth the other terminal, the needle slowly moved up, about the same speed as the normal mini fuel gauge.
Posted 31 May 2007 - 12:19 PM
As stated in various posts above, output from the stabilizer's "I" terminal goes to one of the fuel gauge' spade lugs (either one). The second gauge spade lug gets the green/black wire which goes off to the insulated terminal on the fuel sending unit. The second (earthed) terminal on the sending unit gets a black wire which goes off to chassis ground.
As far as using the old stabilizer, I can't tell you where they are on cars after the Mk3s. However, they won't be in the gauge. On the older cars these were typically little horizontally mounted rectangular metal cans about 25mm long by 16mm high and perhaps 12mm deep. They will have two spade lugs on them, "B" for switched 12V input power, and "I" for 10V output power to the gauges. The stabilizer case MUST be connected to chassis ground to work.
Posted 31 May 2007 - 01:07 PM
Posted 31 May 2007 - 02:31 PM
Posted 31 May 2007 - 03:15 PM
Posted 31 May 2007 - 04:33 PM
That's a very fair price on the voltage regulator you provided the link to. I use the u7810 chip to make my own. From some sources the chip is less than $1 (1/2 GPB). For the seller to offer the chip with leads already on it at 1.5 GBP is great. I'd buy one without hesitation.
Posted 31 May 2007 - 04:37 PM
Posted 31 May 2007 - 04:49 PM
Yes, 13 GBP is a bit steep for that. I can't tell you where to buy the chip in the U.K. but you're looking for a u7810 chip. As is shown on the auction picture, it's a 3-leaded solid state voltage regulator rated for a fixed 10V. They supply up to 1 amp. The mounting tab is also "ground/earth" so the ring terminal shown on the picture is redundant if you mount it using the hole in the tab.
Download my PDF about it:
http://home.mindspri...eStabilizer.pdf
You can easily make your own stabilizer for a lot less than 13 GBP once you locate a source for the chip. You can also use the more common LM317 regulator with feedback resistors but you have to mount that one differently.
