headlights quick question
3 replies to this topic
#1 zeroasylum
zeroasylum
  • 378 posts
Posted 31 May 2007 - 01:40 PM
One of my headlights is very dim like it is not getting enouh power. The other is fine. It is very dim on low beam and on high beam does not get brighter. Could the halogen bulb be going? I recently fitted some relays to switch them on but dont think it is that if one of them is working ok.
Any ideas anyone.
Zeroasylum
#2 Jimmyarm
Jimmyarm
    Entrepreneur of Adult Material
  • 2,239 posts
  • Local Club: TMf
Posted 31 May 2007 - 03:12 PM
When you say 'headlights' do you mean spotlights or the actual main headlights built into the car ?
#3 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 31 May 2007 - 04:05 PM
You sure the main bulb is actually working at all? If it's very dim on both settings it could just be on the sidelight. Check the lamp earth, and the bulb itself.
#4 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 31 May 2007 - 04:28 PM
If after checking the items mentioned above you don't resolve the problem, switch the offending lamp to the other side of the car. If the problem goes with the bulb, replace the bulb. If it stays on the same side of the car look for wiring problems.
