head gasket set query
6 replies to this topic
#1 tricky123
tricky123
  • 85 posts
Posted 01 June 2007 - 02:06 PM
why are there only 4 valve stem seals in a head gasket set ? . i`m rebuilding a head , should all 8 be replaced ?
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 01 June 2007 - 02:12 PM
Common theory is that you only really need them on inlet valves, as the exhaust valves have pressure behind them rather than depression and so oil doesn't get sucked down the stem. So some gasket sets come with only 4 seals. Fitting all 8 is a good idea IMHO.
#3 tricky123
tricky123
  • 85 posts
Posted 01 June 2007 - 02:32 PM
Cheers Dan , thats what i thought , have you any recomendations on head sets. i was going for the minspares one with the AF460 copper head gasket in it.
#4 samwell
samwell
  • 1,520 posts
  • Local Club: SC Spammers
Posted 01 June 2007 - 06:44 PM
geniune. I got mine from minispares. Was about £13 which isnt alot for peace of mind.
samwell
#5 samwell
samwell
  • 1,520 posts
also comes with 8valve stem seals
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 01 June 2007 - 08:17 PM
fitting all 8 is only a good idea if you have high temperature seals, std rubber seals on exhaust valves is not good as they degrade, harden, split and then end up floating around in your oil, with the potential to get stuck in oil ways...
IMO, there's a reason why there's only 4 and the above it..
and unless you've got a freshly faced block and head, stay away from copper....
998 use a std gasket, 1275 use a BK450.
#7 tricky123
tricky123
  • 85 posts
Posted 02 June 2007 - 06:35 PM
Thanks for that , i nearly slipped up there . what compositon is the BK450 , do minispares stock it.
