MOT emmissions - breather
Posted 01 June 2007 - 02:49 PM
I do not run the breather pipes into the carb, they are just in the engine bay therefore i run the carb breather blocked, by unblocking this and making the car idle quite badly, will this lower the emmissions? Also, when people do run the breathers into the carb, when they remove the pipe for the mot, is the goal or that just to stop the gas not entering the carb or is it to let the carb breathe cleaner air, by opening up the pipe.
Also, How would removing the servo/manifold pipe actually aid in the emmissions as my understanding was that it just enabled the servo to work correctly. Thanks
Posted 01 June 2007 - 02:59 PM
If it's a '94 carb with no cat it needs to pass a default emmissions test, which means the CO has to be less than 3.5% and the HC has to be less than 1200 ppm. You should be able to squeeze it down to that with some carb fettling to be honest. Are you using a single 1.75" SU? Unless the car is running quite badly.
Posted 01 June 2007 - 03:03 PM
Posted 01 June 2007 - 03:09 PM
But thats was beacuse I had no idea how to properly set a carb up, which is why it was MASSIVELY over the limit.
Posted 01 June 2007 - 03:22 PM
Just phoned up, they said all 94 cars have to have a cat and so have to be tested as per cat fitted, meaning:
CO< 0.2%, HC < 200 ppm, Lambda 0.97 - 1.03
Surely no carb engined mini can achieve this, even with a cat (pointless)
Will the breather trick affect all aspects? the CO will be, not sure about lambda and HC
Posted 01 June 2007 - 03:26 PM
This has been covered loads of times to be honest. Their emissions test database should tell them that the vehicle should be tested to default settings.
Take it to a garage that knows how to test cars properly!
Posted 01 June 2007 - 03:29 PM
How can i prove he is wrong so that he has to do it to default?
Posted 01 June 2007 - 03:32 PM
The other thing..........
Is it the original engine? Is the engine older than the original one?
Posted 01 June 2007 - 03:36 PM
Posted 01 June 2007 - 03:56 PM
Posted 01 June 2007 - 04:31 PM
First used between 1/8/92 and 31/7/94 - advanced emission test (CAT) if its running on petrol when presented, to the vehicle specific limits usually around CO<=0.3%, HC<=200ppm and Lambda 0.97 - 1.03. Remember from 1st August 2001 a basic emission test will be carried out initially.
so it should have a cat, and once did, however it does not anymore. They will just refuse to try on the other test setting as by the book its 94 and needs a cat... what now?
Posted 02 June 2007 - 11:02 AM
after trying to convince the man for 15 mins that im correct, he obliged to do it the way i said
Thanks for the help, saved me trying to find a tester that knows what they are doing!
Posted 02 June 2007 - 12:37 PM
