taking a door off
3 replies to this topic
#1 mic
mic
  • 1,062 posts
  • Local Club: n/a
Posted 02 June 2007 - 03:10 PM
I assumed it was a straight forward unscrew a couple of bolts and off it comes. but no. i cant get to the screws that hold the hinge to the door by using a screwdriver. so what do you do??
mic
#2 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 02 June 2007 - 03:17 PM
This is how i took mine off. by the way i dont think you take it off using a screwdriver.
1. Jacked the mini up
2. Took the front wheel off
3. un-did the door check strap
4. Not sure on the nut side but there are 4 nuts, when you put your arm up in the arch and behind the a-panel on the hinge panel.
5. once all 4 nuts are removed, just remove the door, be careful though because it is heaver than i expected and if you dont support it well you could easily scratch the paint.
Hope that helps a bit :D
#3 mic
mic
  • 1,062 posts
  • Local Club: n/a
Posted 02 June 2007 - 03:26 PM
poo yea never thought of goin from the other side!!
will try that tomorrow! cheers!
#4 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 02 June 2007 - 03:28 PM
Good luck :D, it shouldnt be very hard to do :lol: but make sure you remove the check strap before you undo the nuts because the first door i took off i didnt then it was a real pane to get off and i damaged my paint.
