Gauge mounting?
2 replies to this topic
#1 jmetal88
jmetal88
  • 289 posts
  • Local Club: okMini
Posted 02 June 2007 - 04:14 PM
I removed a walnut dash that was on my Mini a while back because the veneer was cracking up. Several parts were missing behind that dash. I replaced the gauges with the two-gauge grey pod from MiniSpares (http://minispares.co....aspx?pid=37464), but I can't find any way of mounting them (they're just kind of wedged in to the dash at the moment). I assume there should be some mounting hardware in there that went missing along with that side of my dash shelf and the driver's side dash card (it is a LHD Mini, looks to be 1990 Rover spec, even though the VIN says it should be a 1978 Leyland). Can anyone help me out with how these gauges should be mounted and where I can find the supplies to do so? Thanks.
#2 Edmonds87
Edmonds87
  • 151 posts
  • Local Club: Southern Mini Owners Club
Posted 02 June 2007 - 05:00 PM
There usually held in by a metal frame which is attached to the bulkhead. Im guessing its the same for the two and three clock setup.
Mini spares sell the left and right hand brackets to mount the clocks: http://minispares.co...a...mp;ty=&rt=1
Prob best to give them a ring to double check.
Chris
#3 jmetal88
jmetal88
  • 289 posts
Posted 02 June 2007 - 06:20 PM
Thanks! Hmm... Wonder why the right hand bracket is more expensive than the left hand bracket?
