faded paint
Posted 06 June 2007 - 02:35 PM
what should i do?
Posted 06 June 2007 - 09:43 PM
But is the faded bit a part of the sticker or from where it has been removed?
Try AG Tar remover first.
Follow with AG SRP.
Halfords are doing a 3-2 so also buy either a wash mitt or AG Glass Cleaner.
Posted 06 June 2007 - 09:44 PM
i have a red 93 sprite and where the logo has been taken off the rear quarters, it is possible to see the the logo. i have used alot of different polishes already but none seem to make a difference. its still visable
what should i do?
The paint around the decal will have faded over time, (red is particularly bad for that). Just polish it up with a bit of cutting compound, T cut or G3, just to remove the top faded layer of paint.
Posted 06 June 2007 - 09:46 PM
I would go with AG SRP for the whole panel first.
Less swirls.
Posted 07 June 2007 - 06:52 AM
is it something to do with the pigment in the paint?
ian
Posted 07 June 2007 - 01:31 PM
Posted 07 June 2007 - 01:41 PM
the paint has faded on the whole panel, apart from where the sticker was (still orginal shade)
i have already used AG paint renovator also AG super resin polish, last resort i used a red T-cut. i just dont want to sand the panel or respray it if possible
can anyone tell me whats special about G3 never heard of it apart from this forum. please
Posted 07 June 2007 - 01:49 PM
I use 1200 to sand out dust marks and runs in paint after i have sprayed. then use the G3 paste and a polisher t obring back the paint or laquor to a good flat deep shine.
Its quality stuff and i highly recommend it
Posted 07 June 2007 - 02:09 PM
Posted 07 June 2007 - 02:44 PM
Posted 07 June 2007 - 05:43 PM
It is used by myself and every other bodyshop proffesional I know. It is only too harsh if you don't know what you're doing.
You DO need to use a buffer to get a decent factory finish. Use one of these http://www.tooled-up...e-Polisher-240v If you use G3 without a buff, ie with a cloth by hand you will probably scratch the panel. It needs a uniform movement applied with even pressure. It is also pointless trying to use G3 using a two handled polisher that you can get from B&Q for £10, I've seen people doing this, it is pointless, it'll take far too long and won't do a very good job. You don't have to flat the paint back first with wet n dry paper beforehand, unless there are nibs (bits of sh*t in the paint) or excessive orange peel. If you DO need to use sandpaper, use wet and dry with water as said by mayfairmad, using grade 1500 to 2000. I personally start off with 1500 by hand just flatting any imperfections, and then go over the top using 2000 with a polisher DA (dual action) sander. If you decide to use 1500, you have to go over it after with 2000 unless you want to make alot of work for yourself.
Solid (non metallic) red is particuarly bad for fading due to pigments in the paint being faded by UV rays from sunlight. Yellow and Black are also particuarly prone to fading. This is because if it's a solid colour it is usually applied using a direct gloss, ie one component finish as opposed to metallics which are lacquer over base. You can paint solids using this lacquer over base method, but car manufacturers tend not to as it's cheaper. If you are getting a re-spray in a solid colour, ask for it to be lacquered, this prevents pigment being lost in the paint, as it is protected by the lacquer.
As for dealing with the faded paint around your removed decal, if you cannot get hold of a buffer and G3, I would try Tcut, or if that doesn't work, bring it to a bodyshop and they will buff it up for you for around £0-£30.
Pete
Posted 07 June 2007 - 06:39 PM
Thanks Burt
Posted 09 June 2007 - 08:16 AM
Each to their own, but i prefer Megs 83, Megs 80 then finish off with victoria wax.
But thats expensive, lol
For you, just elbow grease.
Pity your not local.
Posted 09 June 2007 - 09:55 PM
Posted 10 June 2007 - 08:16 AM
Its fine if you know your paint depth and you need something harsh to cut the paint pack, but the thread is about faded paint.
I have had wonderful results with Scratch X and AG SRP with elbow grease.
As I said, each to their own, I just prefer to remove the fade and swirls with a nice gentle cutter rather than a sledge hammer effect!
