clutch fit
wingman
, Jun 06 2007 05:46 PM
6 replies to this topic
Posted 06 June 2007 - 05:46 PM
hi i know there have been lots of questions on this subject and i have read most of them.so just to clear something up .if i remove the verto clutch and fly wheel from my 1275 will the standard 998 clutch fit and work? with the housing and starter thanks.
Posted 06 June 2007 - 08:23 PM
depends what type of clutch it is.
is the "standard 998 clutch" verto or pre-verto?
Posted 06 June 2007 - 09:44 PM
Posted 06 June 2007 - 09:46 PM
it is a standard 998 clutch pre vertodepends what type of clutch it is.
Posted 06 June 2007 - 09:51 PM
if you fit a pre verto clutch & flywheel to the 1275 engine, you will be able to use the original starter and clutch slave cylinder yes.
Posted 07 June 2007 - 03:14 PM
thank you very much what i hoped to hear.if you fit a pre verto clutch & flywheel to the 1275 engine, you will be able to use the original starter and clutch slave cylinder yes.
Posted 09 June 2007 - 10:53 PM
I asked the same kinda question a week or two back.
All the answers I got were different, not that Im turning my nose up at the help!
But in the end, I used a verto clutch in a verto engine.. and I used the non verto transfer case end with non verto arm (and verto bearing) and it works fine. I think I did have to use a verto shaft that pushes the release bearing.
Very confusing to understand, but thats how it worked for me.
