Bonnet Fit
Posted 06 June 2007 - 07:37 PM
it sits far too high at the front and the grill trim dont line up. its like an inch out on the drivers side
i did try and fiddle for a while, but any better fit, and the catch gave up
by the way the catch is almost fully extended from the bonnet too
Posted 06 June 2007 - 07:44 PM
Basically, the only way i could get the bonnet catch to grab the bonnet and grasp it with any certainty was to make the bonnet look like poo
get rid of the hinges and catch and fit bonnet pins and then straps/springs!! makes it easier to work on the car too.
Posted 06 June 2007 - 07:47 PM
Thats on my list of jobs to do.
Posted 06 June 2007 - 07:48 PM
Posted 06 June 2007 - 07:50 PM
Posted 06 June 2007 - 07:59 PM
Posted 06 June 2007 - 08:04 PM
il find a picture!
http://www.theminifo...x...740&hl=dzus
their the ones on the bonnet of the green minus!
Posted 08 June 2007 - 09:16 PM
Posted 08 June 2007 - 11:23 PM
Edited by Jamier101, 16 November 2012 - 09:14 PM.
Posted 09 June 2007 - 06:32 AM
Posted 09 June 2007 - 08:38 AM
unless there is something wrong with the car (bent panel, cheap bonnet etc.) you should be able to get it to fit !!???
very strange !!
Posted 09 June 2007 - 09:29 AM
the bonnet may well be a cheap nasty one for all i know, some one has bodged the bonnet hinge bolts, as they have welded the bolts to the hinge, so there is FA adjustment on the rear
Ed
Posted 09 June 2007 - 09:44 AM
the "dogs knob" is adjusted as far as it can go almost without falling off, and cant seem to adjust the angle too much
Ed
Without seeing it's differcult, when you close the bonnet is the bonnet basically in the right place, but the bonnet catch assembly is out of alignment, the female part of the bonnet catch assembly ie the bit bolted to the landing panel, if you slacken the two bolts of there you will be able to move the assembly loads as it's on slotted holes, you shouldn't be bending or twisting anything unless something is very wrong
David
Posted 10 June 2007 - 09:54 AM
i will have a look at adjusting the female part in a bit.
Posted 10 June 2007 - 02:47 PM
refitt the bonnet peg just a few turns, drop the bonnet down and look to see if it lines up with the catch, adjust the catch so the peg lines up, if the peg needs moving further back or forward you can bend it by hand, if it needs moving further to the side and all the catch adjustment has gone file the holes bigger.
now close the bonnet and screw in the peg to bring the bonnet further down just a couple of turns at a time.
