A strange water leak!!
Posted 07 June 2007 - 12:01 PM
Posted 07 June 2007 - 03:43 PM
Posted 07 June 2007 - 05:56 PM
Posted 07 June 2007 - 06:30 PM
Posted 07 June 2007 - 06:55 PM
Posted 07 June 2007 - 06:58 PM
Well I'm out of idea. All torqued down right isn't it. Been told to do it twice in the past.
Posted 07 June 2007 - 07:28 PM
Posted 07 June 2007 - 10:00 PM
When you torque it down, you must let the engine heat up to temperature and cool down once. Then release and re-torque each nut, in the same sequence as fitted. That is immediately, after just 1 heating cycle and not after 100 miles. The head isn't torqued until that's been done and will pretty much fail every time if you skip this part. And don't just tighten the nuts, release and then re-tighten each one. Don't be tempted to release them all and then re-tighten them all either as that will almost guarantee a leak. And don't rev or drive it while it's heating, just start it and let it idle up to temperature gently before switching it off and letting it cool fully.
Posted 08 June 2007 - 09:17 PM
Posted 15 June 2007 - 11:23 AM
Posted 15 June 2007 - 01:10 PM
Posted 15 June 2007 - 03:28 PM
It's the right thing to do but it will only work with a new head gasket. Once it's started to leak there is no real way to re-seal it. You might be lucky but if you find it is still leaking you will have to change it.
sorry dan forgot to mention ive actually changed the head gasket lol so hopefully all shall be well now!!!
p.s is there anything else i need to do i.e drive it less aggressivly for 200miles or something??
Edited by Danny Boy, 15 June 2007 - 03:31 PM.
Posted 15 June 2007 - 04:14 PM
Posted 15 June 2007 - 09:36 PM
So long as all the push rods went back in the holes they came out of, no running in is required. If they got mixed up then you should let it run in for a couple of hundred miles. Re-set the tappet clearances now that you've re-torqued the gasket, and do them again in a month.
yeah ive put push rods back in the same holes and done the tappet clearences thanks alot for helping!!!!
