Is it ok to mix different makes of adjustable shocks ie Gaz on the front, Spax on the rear?
blakie
Shocking Question
blakie
, Jun 10 2007 09:46 AM
4 replies to this topic
Posted 10 June 2007 - 09:46 AM
Posted 10 June 2007 - 10:44 AM
Cant see why not, but dont use for example one spax shock on the rear drivers side and one gaz shock on the rear passenger side, keep the same makes in pairs...
Could be completely wrong though lol
Posted 10 June 2007 - 10:51 AM
best replacing in pairs as stated above.
Posted 10 June 2007 - 11:01 AM
Thought as much so,
What the best value for money kit out there?
Ive just noticed the ADJUSTA>RIDE (£95) kit in minisport, You dont get dampers but you can use your origanal dampers can i?
Or i have noticed the SPORTS>RIDE kit in the same place, the gmax one (£155) looks quite good value for money.
I just want your view really
blakie
blakie
Posted 10 June 2007 - 11:35 AM
you can use your standard shocks with the HILO or adjustarides, unless you lower it too much, you'll then need lowered shocks...
how low is too low, or if you can get too low with HILO, I dont know
but with a bit of search you'll find all that answers for sure, been discussed many times
