I can see the 2 holes on the side of the 2nd gear retainer, but they dont seem to line up with any plungers underneath. I have held it up to the light and looking through the holes all I see is solid shaft... what have I done wrong or forgotten?
Posted 22 July 2007 - 10:30 AM
Posted 22 July 2007 - 10:40 AM
Posted 23 July 2007 - 07:31 AM
Posted 23 July 2007 - 08:19 AM
The holes in the gears are used during assembly not dissassembly...
What you need to do is slide a fine screwdriver (or similar) inbetween the ring (marked red) and the detent(plunger) in the shaft, pushing it in, and then when able rotate the ring to lock the plunger in.. you then do the same with the other plunger making sure to rotate the ring the same way as not to allow the first detent to pop back out... when both are in the ring must be fiddled into position so the gear can be withdrawn..
Posted 28 July 2007 - 07:33 AM
Posted 28 July 2007 - 07:54 AM
Posted 28 July 2007 - 08:08 AM
Posted 28 July 2007 - 11:15 AM
