lighting problems
Posted 10 June 2007 - 09:40 PM
Posted 10 June 2007 - 09:45 PM
by the way, have you corrected the fuse ratings for the blade fuses?
Edited by Dan, 10 June 2007 - 09:45 PM.
Posted 10 June 2007 - 09:50 PM
(no the battery is not flat!!)
Posted 10 June 2007 - 10:02 PM
And no, I'm not talking about those. There is a cluster of connectors where the front and rear looms are connected to each other. I belive it's always in the engine bay, around the wiper motor area but it could be inside the car behind the dash liners. Check that the red/green one is intact.
Was it just the ones you mentioned above that went out after being on?
Posted 10 June 2007 - 10:31 PM
When you say the correct rating, do you know that the correct rating for a blade is different from that for a cartridge? You should use a blade rated at half the rating of the cartridge. The reasons for this I have written down about four times in the last two days and so I'm not doing it again now.
yes it was just those that went out and after checking the diagram i see that the red/green is the power feed for the rear lights will have a check around tomorrow. and the loom is in bits now as i had to change the red wire from the light switch also as it had melted over time
