Removing and fitting an engine
Posted 11 June 2007 - 06:21 PM
I have ordered a new engine and need to address a few areas of corrosion in the engine bay.
My first question is, what is the best way to get the engine out - from above or below?
Secondly, I am going from a 950 cc engine up to a 1380. I have ordered new carbs, distributor, ignition, Cooper S brake conversion kit and exhaust system. Are there any other ancilliaries I need to upgrade which I haven't considered?
I have also been told that I may have to change the subframe, however, I don't think this is the case. Any ideas?
Many thanks - I'm now starting to get very nervous!!!
MK
Posted 11 June 2007 - 07:36 PM
Think it's 10 or so bolts. Fuel pipes disconnected, brake pipes disconnected, couple wires and the carb off them drop it down. You'll be able to weld everything lots of space spare until you plonk the new engine in.
Thats my plan. You'll need a mate or two to lift the body off the engine.
Posted 11 June 2007 - 08:09 PM
MK
Posted 11 June 2007 - 08:25 PM
It's in the haynes.
Posted 11 June 2007 - 09:08 PM
So I hold the car with some axle stands, lift up the front and literally wheel the subframe out with the engine. Can I take the engine off the subframe and temporarily refit the subframe if I need to move the car around while I'm working on the engine bay?
MK
I used this method when i took my engine out. Except i jacked up the car as high as possible and placed a piece of 4" x 2" across widthways on the underside of the front of the car (near the factory jacking points):
1053268249a3687545694b402586465l.jpg 51.45K 12 downloads
Having removed the wheels, hubs, calipers etc, I supported the subframe with a trolley jack and another piece of wood width ways across the front subby, took all the bolts/mountings holding the subframe to the body, then carefully dropped the subframe on the jack to the floor and slid it out underneith the body.
Only did it this way as i had no engine crane and was easier than hiring one out. Once all was good in the engine bay and the subframe had a coat of hammerite i refitted just the subframe and hubs etc to the car so i could tow it to my new house then fitted the engine when it was ready with a crane:
1053268249a3805476640b562837922l.jpg 50.82K 15 downloads
Ive tried to add a pics of mine whilst it was being done so u can see where i supported it.
Hope this helps
Chris
Edited by Edmonds87, 11 June 2007 - 09:10 PM.
Posted 11 June 2007 - 09:29 PM
you will need a spacer for the fan and a cooper s rad bracket for starters too
which drive shafts does your new engine have too
dave
Posted 11 June 2007 - 10:41 PM
that youve got too much money =p lol. wish i could 'buy a new engine' good luck. Engine from under every time, lift the car.
Posted 12 June 2007 - 07:04 AM
Posted 12 June 2007 - 07:06 AM
MK
Posted 12 June 2007 - 08:02 AM
Hi Dave, I have no idea about the drive shafts as this is something I havent considered. I suppose I will only find out when I get the engine out?
MK
does it have a wand box atm?
dave
Posted 12 June 2007 - 08:08 AM
Mark
Posted 12 June 2007 - 08:15 AM
Posted 12 June 2007 - 08:19 AM
Mark
Posted 12 June 2007 - 12:11 PM
Posted 24 June 2007 - 07:48 AM
