Kent Cam confusion??
Posted 12 June 2007 - 04:45 PM
Posted 12 June 2007 - 05:20 PM
Are you measuring the cam using anything precise? Or just a tape measure or similar?
I've heard tell that the Kent profile's aren't the best as the original base is quite old now, but I wouldn't worry. I had a 266 in an otherwise standard Metro 1275 and it was great.
Posted 12 June 2007 - 05:50 PM
Posted 12 June 2007 - 06:32 PM
It's not the physical size of the lobe (point to point) that's important, it's the lift off the baseline diameter. What this means is, you can't measure the lift using dial calipers per se. A better method would be to slowly spin the cam while it's supported on centers. Zero the dial indicator when you've found the low spot, then turn the cam and measure the maximum lift above this datum.
If you don't have this, the best you can achieve with dial calipers is to measure across the cam lobe along the "narrow" axis (perpendicular to the lift. ) Record this value. Now measure the maximum dimension from the tip of the lobe to the far side (along the axis of lift. ) Subtract the first measurement from the one taken in the direction of lift. The difference between the two should be close to the maximum published cam lift.
However, as stated above, it's not jut the lift of the cam that's important, it's how the lift occurs... the profile of the lobe. The only way to measure that is with a degree wheel and dial indicator.
Posted 12 June 2007 - 07:42 PM
Don't think you can go by that as the metro cam may well be worn so will give a false impression.yer we measured it with a digital vernier gauge and the lobes on the kent are more pointy and are smaller than the lobes on the metro cam i thought it was the bigger or more domed the lobes are the better the performance i.e more fuel and what not..
Posted 12 June 2007 - 08:55 PM
Posted 12 June 2007 - 09:21 PM
Posted 12 June 2007 - 09:34 PM
Posted 12 June 2007 - 09:37 PM
As DK has already explained. A normal Kent Cam would be a re-profiled camshaft. Your Metro one will be made from a blank.i know what your sayin about the metro cam may be worn but even if it is its still bigger than the kent one. would i still have to use 1:5 roller rockers or can i use normal 1275 rockers. are the rockers just to get max performance or is it a must have please help?
Basically, they take a cam like the one you have, grind it down to a different profile, then put it in a box. The lobes may be smaller, but the lift will be different.
Posted 12 June 2007 - 10:49 PM
Posted 13 June 2007 - 02:50 PM
Posted 14 June 2007 - 10:05 AM
