hi every1,
i was wondering if i put a hif 44 carb on my 1275 a series engine which has a maniflow lcb exhaust system (apart from that its standard), would it increase the
performance of the car on its own?
HIF44 1.3/4" carb
mycoolmini04
, Jun 13 2007 10:31 PM
7 replies to this topic
Posted 13 June 2007 - 10:31 PM
Posted 13 June 2007 - 10:33 PM
what carb did it have previously?
yes oli it will as long as you have the carb and timing are set correct
Posted 13 June 2007 - 10:37 PM
it's currently got a 1 1/2" carb.
sorry dan just double checking lol
Posted 13 June 2007 - 10:41 PM
im gona put 1on minie when if fit the 1275 kels got one on his
Posted 13 June 2007 - 10:44 PM
oh good good i will definently be buying one and fitting it then
Posted 13 June 2007 - 11:39 PM
If your old carb was a HS then the Hif is better. a 1275 will cope with a 1 3/4 carb. of course if the Hif is knackered or badly set up you'll lose more than you gain.
Posted 14 June 2007 - 05:22 PM
i went from a HS on my 1275 to the HIFF44 and i instantly noticed an increase in tourque, it was actually quite suprising how much of a diffrents it makes!!!
