- Offset bored to 73.5mm
- 11 stud conversion
- surfaced up to 0.30"
- New cam bearings
- Steel centre main strap
Gareth
Posted 14 June 2007 - 11:59 AM
Posted 14 June 2007 - 12:02 PM
Posted 14 June 2007 - 12:13 PM
When they bore it, they'll probably cross-hatch hone it too.
Umm, new oil pump, decent steel backed job,
Water pump upgrade,
decent shells, (size dependant on crank regrind)
Posted 14 June 2007 - 12:21 PM
If i were to take a standard 1275 and have the following work done on it...
what other standard componants will need replacing/modifying? considering it will have a modded head, sw5 cam, twin su's and a cross pin diff. I will prbably use ARP Head studs and rod bolts too.
- New cam bearings
Gareth
Posted 14 June 2007 - 12:42 PM
- New cam bearings
Gareth
mine has only 9 stud head with ARP's and thats 120bhp so i dont see why you would need 11
i would put the list up of what i have changed but it would take agers and it would depress me looking at all the bills
Posted 14 June 2007 - 12:44 PM
Posted 14 June 2007 - 02:10 PM
Posted 14 June 2007 - 02:23 PM
Posted 14 June 2007 - 03:26 PM
Posted 14 June 2007 - 03:32 PM
lol Raz.
i think you would have to change the cam too
Posted 14 June 2007 - 08:50 PM
Posted 14 June 2007 - 11:11 PM
Posted 15 June 2007 - 10:10 AM
