12" to 10" Engine rev.s....
choodalls
, Jun 14 2007 04:44 PM
6 replies to this topic
Posted 14 June 2007 - 04:44 PM
Hi,
I have fitted a 1275 cc metro automatic engine and gearbox to replace my original 998cc mini auto engine/box. The Metro engine will have been used with 12" wheels, but I want to keep my 10 inch wheels (with disc brakes). Will the engine be revving its nuts off, or is it able to take it? Really don't want to go into the auto box innards and play with final drive ratios - so if it's a real problem then I'll run it on 12 inch wheels......
Anyone out there gone from 12 down to 10 inch without changing final drives? Have you had problems?
Dave.
Dave.
Posted 14 June 2007 - 05:18 PM
1275 is fine on 10" wheels but your speedo will read incorrectly. I take it you've got 7.5" discs fitted if you want to keep 10" wheels?
You could always get the speedo recalibrated.
Posted 14 June 2007 - 05:32 PM
or change the speedo gears for mini ones I have a couple of automatic sets
dave
dave
Posted 14 June 2007 - 05:38 PM
guessworks has a good guide to this
Posted 14 June 2007 - 06:13 PM
You should change the speedo gears, I seem to remember that Mini speedo cables don't properly fit Metro speedo gears. Or maybe I made that up......
If the cable does fit the gears, the difference in speedo accuracy will be dependant on more than the wheel size. You really need to find out what FD is in the two gearboxes currently.
Posted 14 June 2007 - 09:58 PM
Thanks. I am going to also finish off a conversion to centre binnacle, and will let Speedy Cables do the speedo recalibration....and yep, I have a set of Cooper S discs.......just wanted to make sure that the Metro set-up wouldn't rev its nuts off on 10 inch wheels.
Ta.
Posted 15 June 2007 - 10:16 PM
you will lose a bit of top end to the swap but will gain a bit more acceleration!!!
Great fun thou!!!!
Great fun thou!!!!
