bleed'n brakes :(
Posted 15 June 2007 - 09:36 AM
Quick overview of the brakes
minsport ally 4 pots (set up for 7.5" brakes), 1 bleed nipple per wheel (nipple at the top)
refitted tandum master cylinder and pressure valve thingy (all working fine when poote was taken off of the road)
stock rear brakes (but with superfins fitted)
We have got clean fluid out of all the nipples , good brakes at the rear but no peadle pressure or front brakes. The pistons are moving out and if you pump the peadle quickly you get some pressure, but as soon as you let off and re apply there is nothing.
We have cracked of the joints at the pressure valve jobby and there is fluid moving comining out of all ok.
Any ideas?
Posted 15 June 2007 - 10:38 AM
Posted 15 June 2007 - 10:43 AM
(nipple at the top)
Posted 15 June 2007 - 11:21 AM
1st thing we checked. Nipple at the top.Did you put them on the right way up (common problem).
Posted 15 June 2007 - 11:22 AM
fluid was coming out of the nipples but,there was air in the servo...
i don't know if there is any difference with your servo,if you have one...
Posted 15 June 2007 - 01:14 PM
Posted 15 June 2007 - 01:24 PM
Posted 15 June 2007 - 01:55 PM
All the hose joints and pipe unions tight?
I'll double check, but none where seeping any fluid
Posted 15 June 2007 - 06:27 PM
Posted 15 June 2007 - 07:22 PM
if u press the pedal slowly... does the pressure drop as the pedal pressed. i think this indicated the master cylinder letting by.
pressing the pedal slowly and I get no pedal pressure, only if it is pumped quickly do I get any
Going to get an easy bleed on it tomorrow and see whats what
Posted 16 June 2007 - 05:01 PM
It seems I had plumed the master cylinder in back to front (don't know how as I reused the pipes). Still got a bit of a long brake pedal (don't know if thats normal for a non servo'd set-up with 4 pots) but they seem to bite fine.
The test will be when we take him out for the first road test
Posted 16 June 2007 - 05:31 PM
4 pots have slightly more overall area than the standard mini setup (80.97 sq cm to 80.754 sq cm) so fractionally more pedal travel should result.
As the min has a vertical master cylinder some air can get trapped at the top, suspect swapping pipes may have let it escape. Pays to loosen pipe joints and bleed through them too sometimes.
If you find your pedal is too long there is a smaller bore rear cylinder available it was fitted without a pressure regulator.
Posted 17 June 2007 - 07:38 AM
I suggest very early morning then.....
We have non-servo brakes and the pedal travel is quite small, about 25mm, moving a bit more most time my daughter uses it though...
