headgasket
Posted 20 June 2007 - 01:06 PM
cheers
Posted 20 June 2007 - 01:32 PM
Actually doing it is pretty simple, just a case of undoing nuts etc. You will need a torque wrench for putting the head back on if you dont have one already
The haynes manual is your friend for this job.
Edited by Jimmyarm, 20 June 2007 - 01:34 PM.
Posted 20 June 2007 - 01:47 PM
how easy is it to change the head gasket, and does any one know were i could get 1 from and where could i send the head to get skimmed, as i am thinking of buying this mini but the head gasket has gone he thinks, also it splutters what could this be, just carb tunning or bad fuel filter?
cheers
Head gasket from - Motorfacotor shop. You want a copper one.
Head Skimming - Check the yellow pages for a machine shop.
Chaning is easy enough if you engine is all stock parks. Stage 1 bits make it a bit of pain.
Posted 20 June 2007 - 01:59 PM
Posted 20 June 2007 - 05:00 PM
For a total newbie if you have the tools and a can of penetrating oil it is a very satisfying weekends work and it will pay dividends with efficiency.
All the information you need is in any of the service manuals, and most is on here as well.
Oh and Minispares does a full kit, all the gaskets you need and the seals. You will need this because you have to replace more than just the head gasket.
For an idea how long it takes, first time I took it off took me 2 hours, second time, after I realised I hadn't fixed the problem was 15 mins from engine running to on the bench!!
Posted 20 June 2007 - 11:36 PM
Posted 21 June 2007 - 10:22 AM
thanks for all the replies, but if its not the head gasket what could it be please?
How long is a piece of string? If the bodywork on the car is good and you like it and the price takes into consideration the running problems buy it. Then start some serious investigation of the problems, depending on the age it could be a number of things, C**p points, timing out, dodgy plugs, C**p in fuel, old fuel, mixture etc etc.
All of these things are easily corrected at home with minimal skills, just some diligence.
Posted 21 June 2007 - 10:32 AM
You could pay for an AA inspection or similar.
If you can manage the job yourself, you could probably swap a complete engine 'n gearbox for under £200 so if the price is right......
Posted 21 June 2007 - 01:28 PM
Could be anything, since you haven't said what it is that makes you think it's gone. If the guy who owns it now thinks the gaskets gone he's probably got a reason to think that so it probably is. Lots of problems are caused by broken head gaskets, it's fairly common on A series engines and luckily quite easy to replace. Nobody said it wasn't the head gasket.
Posted 22 June 2007 - 12:18 PM
