Fuel in oil!!!
Posted 23 June 2007 - 06:45 PM
Having now drained it all out (aprox 7-8 litres of liquid came out of the sump) there will surely be a film of oily fuel lining the inside of the engine!? how would i go about flushing the engine to ensure i get rid of all the C**p?
Also is it likely to have done much damage to the internals of the engine? I don't have a clue how long the fuels been getting ito the oil. I only notices it as it was leaking from one of the breathers a few days ago. I never had the chance to run it on the road but have run the engine with the car stationary for approx 1.5 hrs in total since rebuilding it!
Posted 23 June 2007 - 07:08 PM
1st one cheap oil drove the car with slipping clutch got oil hot then drained it out and then put the dear oil in clutch seemed to cure itself after
awhile aswell took clutch apart 1 year later not a pretty sight in there at all.
Posted 23 June 2007 - 07:12 PM
Fuel "should" evaporate naturally.
...I think.
Posted 23 June 2007 - 07:24 PM
You are probably right about the fuel pump diaphragm being the cause, it's the most likely thing.
Since you have removed the majority of the fuel by dropping the oil you have reduced a lot of the risk. Do as Adam says and let it ventilate overnight (rocker box off entirely, not just the cap and pull the emissions hoses off the breathers) for safety if you are worried. Obviously don't now let it fill with rain water! Reassemble, change the filter too and fill it with cheap oil and a can of oil flush. Run it for 15 minutes and change it again (oil and filter) for some proper oil.
There could be damage due to oil being washed out of the bearings or off the cylinders but there is no way to tell without stripping it down. Treat it carefully for a while (it is still running in anyhow) and see how it goes would be my advice. It has only been running for a short time but damage to bearings can happen in just minutes if the oil is seriously diluted. I would say run it in like normal and see how it goes.
Oh yeah, and get a new fuel pump!
And incidentally it is not good for a newly built, running in engine to sit and idle or run with no load for any length of time. You will prevent the rings from bedding in properly if you allow the cylinders to glaze. Run it in properly and it will last a long time. Don't and it won't.
Edited by Dan, 23 June 2007 - 07:27 PM.
Posted 23 June 2007 - 08:05 PM
Hey Dan - would you care to elaborate a little more on this? I remember years ago I ran an engine in overnight in preparation for a rally by driving at a steady 40 or so for about 400 miles, without revving it or loading it too much at any point, i.e. just gentle driving. What advice have you got?
Posted 23 June 2007 - 09:28 PM
Edited by Dan, 23 June 2007 - 09:30 PM.
Posted 25 June 2007 - 05:17 PM
Having taken the suspect fuel pump off today ive found no visible damage to the diaphragm on the pump. I blew through the inlet of the pump whilst pluging up the outlet before taking the pump apart and there were no leaks whilst doing this.
Are there any other places the fuel could be getting in? apart from the pump if the pump is not the cause?
Posted 25 June 2007 - 08:39 PM
Posted 25 June 2007 - 09:19 PM
I still suspect the pump just put a new one on and it will probably be fine, blowing through it is not a indepth test really
Ok thanks jonny just wanted to cover my a*** as the list of bits ive bought before, during and after the rebuild of this damn engine to try and get it working properly is never ending! There's always something going wrong which needs fixing! AAHHHHHHHH! And it doesnt help that im now without a job and overdrawn!
Y DO WE BOTHER????
Posted 25 June 2007 - 09:23 PM
How is the oil consumption ? How many miles have you done ?
Posted 25 June 2007 - 09:46 PM
Wasn't until the other day that i read up about the charcoal canister usually placed in the front passenger wheel arch. This i never re-fitted after the rebuild. I didn't want it pumbed in as wanted the breathers fitted with breather filters insted of the evaporative emmisions control system so ran the fuel return from the carb overflow directly from the fuel return to the tank, vented the two breather to fresh air with filters and connected the vacuum pipe from the carb directly to the vacuum advance on the distributor thus allowing me to remove the canister. However i have read that without it connected it can cause staring and running problems so decided to refit it.
It was only after refitting this that i started the car to find that it chucked out a load of white smoke out the exhaust once it started and then cut out. Was after this i discovered the fuel in the oil. Could it be that ive reconnected it wrong? Would this cause fuel to be pumped into the sump? Perhaps through the breather pipes?
