unpredictable handeling
MiniRHK
, Jun 29 2007 05:49 PM
18 replies to this topic
Posted 29 June 2007 - 05:49 PM
The new car just doesn't handle like the old one . I've had a new steering rack and the front ball joints adjusted as there was a bit of play in the front right one, this has helped but the car still feels 'floaty' in the handeling department.
I know the 13" wheels are renowned for tramlining but this is not what is hapening as i was used to this on the old one. could it be worn cones or shocks ?? :S
Any help woudl be great thanks and its kinda taking away from the fun of driving her
Posted 29 June 2007 - 05:55 PM
or subframe mounts
Posted 29 June 2007 - 06:01 PM
How can i test for these faults ??
Posted 29 June 2007 - 06:07 PM
open bonnet and look into engine bay
get a mate mum, Granny etc to turn steering wheel
see if the engine turns in the engine bay
Posted 29 June 2007 - 06:10 PM
Thanks . What about cones? Its true that if you bounce the suspension and it doesn't dampen quickly its shot ?
Posted 29 June 2007 - 06:14 PM
that is to test the shocks on a standard car. not too sure if it will work on a mini as per the cone set-up. it should there is no reason why it wont bar the fact of the limited movement in the mini suspension.
HTH James.
HTH James.
Posted 29 June 2007 - 07:22 PM
What about the bushes on the suspension, tie bars etc ? how are they looking ?
Posted 29 June 2007 - 09:56 PM
Don't know the solution ere but I have just fitted new suspension donuts and they have created much the same floaty effect totally ruining my enjoyment of the mini, it was very tight before. wonderde if I should fit Hi Lo's? Or wait and see it it settles down again (currently about 6inces clear of the arches!)
Posted 29 June 2007 - 10:02 PM
HH: How long ago did you fit the donuts? You'd expect more roll with new donuts though, as they will compress more than the old ones.
RHK: I definitely check the condition of all the suspension bushes as Jimmy says. Also check that the splines on the end of the steering column aren't worn.
Posted 29 June 2007 - 10:10 PM
[quote name='jammy basturd' date='Jun 29 2007, 11:02 PM' post='579758']
JB: I only replaced these yesterday as I said it is sitting quite high at the mo!
Posted 30 June 2007 - 12:12 AM
heavyhasso - the new donuts take a while(few months) to settle down.
mini rhk - is everythig std on both cars? mite jut be a difference in setup...neg camber, stiffer bushes, dampers, springs, even tyre pressure, tie bars, bearings....
Posted 30 June 2007 - 01:45 PM
Does it pull in either direction?
Posted 30 June 2007 - 01:52 PM
Some Suspension bushes are brand new, were replaced by the garage b4 i got her. I'll have a look at the tie bar's and the rest of them.
Tried greasing her nipples the other day ( can i say that on a family forum... ) anyways some worked alright but some just seemed blocked. i took out the nipple and it was fine, no blockages, guessing the joint is pretty gunged up.
Could this be something to do with the handeling :S
Posted 30 June 2007 - 01:54 PM
It skips about in both directions... but not really pulling as such, everything on both cars is the same by the way, or should be !
Posted 30 June 2007 - 02:44 PM
Donuts will settle - always way high after refitting
Shockers - even on a mini you should see their effect push down on the car to make it rock on the suspension, if the shockers are good it should settle within 1 or 2 pitches once you tkae your hands off - rig yourself a pointer if it helps to see
