Welders
Posted 02 July 2007 - 01:11 PM
I'm probably going to go on a night school course in September to learn to weld properly, but in the meantime I have some odd bits and pieces to do which a welder would help with, even with my basic skills, so I'm thinking about purchasing a cheap welding kit such as this:
http://www.frost.co....?productID=8349
Is that any good?
Posted 02 July 2007 - 01:17 PM
Get a good GASSLESS MIG welder or a gassed one.
Edited by Big_Adam, 02 July 2007 - 01:17 PM.
Posted 02 July 2007 - 01:35 PM
Looks like an ebay job then
Posted 02 July 2007 - 01:37 PM
if using it on a car. its a bit to messy.
stick with a gassed mig.
oli
Posted 02 July 2007 - 02:27 PM
Posted 02 July 2007 - 02:37 PM
Get the biggest mig you can afford, just like cars you'll want more power sooner or later.
I like gasless as I don't weld very often it's much more convenient.
Forget the little disposable gas bottles you can buy in places like Halfords they last two minutes 'n will have leaked away before your next welding session.
Proper sized refillable bottles are the best setup if you can justify the outlay.
Posted 02 July 2007 - 02:45 PM
Posted 02 July 2007 - 07:52 PM
Posted 02 July 2007 - 09:47 PM
how did you get enrolled onto the welding course i went to do one last year at lincoln college and they turned me away as the government had given them targets to get young uns in (im only 26) because of the shortfall in the trade and you had to have proof that you were going into a job in that particular trade !! ( asuming you aint a young un of course)
Posted 03 July 2007 - 08:26 AM
i did all my welding with a gasless and i had a 130 snap on gassed found the gassles much better could you not stick gassles wire though a gassed welder using the correct tip and no gas of course.
Ta for the reply... I'm not actually on the course yet, the prospectus is on my desk!! I hadn't heard about restrictions etc and I'm almost 40 so fingers crossed!! I'll let you know if I have problems
Posted 03 July 2007 - 09:57 AM
A good quality 130amp welder will do everything for the car and any household/garage jobs, but the smaller hobbymigs available would certainly be good enough for any car, but you may struggle to find a hobbymig that can run 0.8 mig wire, my murex tradesmig on car bodywork rarely goes above 40amps.
The hobbymigs are not best for quaility and or reliability so I've heard, I've never bought one but have used a few in the past to see how they perform, certainly good enough, found it quite easy to get nice welds, would be fine on a few home car restorations
David
Posted 04 July 2007 - 03:28 PM
Thanks for the advice etc etc... I have taken the plunge!!
For around £230 I will have a Gasless 150 amp Clarke unit with the necessary gas conversion items needed to run it with gas. I'll also be getting a BOC gas bottle (small sized) on rental for about 50 quid. The course enrollment has been fine... all done!
Meep meep! I must be mad
Posted 07 July 2007 - 03:33 PM
