So am guessing timeing?
Takes a few mins of cranking before fires up, runs with a splutter (nearly a miss-fire) and then once warm moves along well.
And whilst on the subject, the rev counter bounces around too.
Ideas?
Trouble Starting When Cold
smudger
, Jul 06 2007 05:28 PM
3 replies to this topic
Posted 06 July 2007 - 05:28 PM
Posted 06 July 2007 - 08:11 PM
Leak on the manifolds somewhere perhaps, is the idle erratic or going up and down when you get it going ?
Have you set the choke properly ? Mine will splutter if you pull it out too far when its cold
Posted 06 July 2007 - 09:14 PM
is the coil ok?
Posted 06 July 2007 - 09:32 PM
Well, fitted a Maniflow stage 1 with Somerford Inlet (whilst its nice and flat, the finish leaves alot to be desired) and all new nuts and washers. However, i might of fitted the maniflod gasket the wrong way, and the servo take off might not be sealing properly.
I used wd40 around all the seals and cant find any bubbles, so guessing no leaks.
So i reckon: timing, carb sticking and as for the rev counter, coil, loose connector or fuse connectors are shagged.
But before i get it on the rolling road, i need the bracket from gearbox to manifold.
