Turbo engine
Posted 20 December 2004 - 06:24 PM
Regards
David
Posted 20 December 2004 - 09:34 PM
A+ block {surface ground}, +.20 rebore Omega cast Turbo pistons, A+ rods & crank {reground if needed}, lightened steel flywheel and backplate, grey diaphragm + rally/race plate, Piper phase 2 cam, duplex chain, Avonbar Turbo oil pump, modified head {36/29 valves}, standard Payen Turbo gasket, A+ "Y" head studs {head & block tapped for 10th & 11th studs}, Trannex twin pin diff, sc drops, standard box fully rebuilt {properly !!} & a good intercooler.
Providing it's built properly a decent Turbo motor as above, will be a reliable road engine capable of 130+hp and thousands of miles. A well built engine is the key to reliability, not just a load of fancy parts !
Now if moneys no object, and you want an all out monster, well ..........................
Phil. :grin:
Posted 20 December 2004 - 09:44 PM
Thanks Phil
Posted 21 December 2004 - 12:54 AM
Posted 21 December 2004 - 08:45 AM
Phil. :grin:
Posted 21 December 2004 - 09:52 AM
PISTON METRO TURBO MEGA 9.4cr +40 ONLY 9.38cc DISH P22357-40
£210
Posted 21 December 2004 - 09:53 AM
Minispeed
Turbo 9.4cr with 11.3cc dish available in 40. P22357S
£235
No Picture..
Surely the second ones would be better in +040 because they hasve a bigger dish..
which = lower CR and more boost can be applied ?
Posted 21 December 2004 - 09:58 AM
alex
Posted 22 December 2004 - 10:59 AM
I'll get the part number and a photo if you want?
Posted 22 December 2004 - 11:17 AM
Posted 22 December 2004 - 12:24 PM
Ain't making no promises! As you know my mechanical knowledge is that of you average Organic Banana but they defo ain't a standard dish. I hope!!!!
I'll MSN it up if you around about then and if they are right well talk prices, because i'm down in Plymouth from the 27th so might be able to save ya on postage!
Posted 22 December 2004 - 04:22 PM
Around the rim; 71.588
and the .040"
In the dish Sp 0.04 and Y5A and after that a crazy squiqle
Picture soon just gotta get some batteries
Anyone know?
Posted 22 December 2004 - 08:25 PM
alex
Posted 22 December 2004 - 10:32 PM
Posted 22 December 2004 - 11:01 PM
it could well be somthing like 20831
alex
