I decided to make some changes to the indicators taking out the side repeators, that was the easy part. Now the indicators won't work. The clicker will work on bother sides, but no lights. When i unscrew the indicators from the body, the indicator comes on but does not flash. I have checked all the earths and cleaned them. I have gone over and over my tracks and cannot see what is wrong. any help would be sooooooooooooooooooooooo much appreciated. If i had hair i would be pulling it out by now. :?
sooooooooooo need help
philc
, Jul 07 2007 04:37 PM
8 replies to this topic
Posted 07 July 2007 - 04:37 PM
Posted 07 July 2007 - 04:50 PM
You've removed your side repeaters? Good luck at the MOT or if you ever get pulled over then.
Problem could be in the hazard switch. Anything else not working?
Posted 07 July 2007 - 05:09 PM
hazard switch keeps blowing its fuse, everything else is fine
Posted 07 July 2007 - 05:17 PM
The hazard switch is where the indicator and hazard systems are joined. Try replacing it.
Posted 07 July 2007 - 07:39 PM
i will give a go. it is the indicators on the wings i can taken off.
Posted 07 July 2007 - 07:54 PM
what year is your car because after a certain year all cars must have side indicators 85 rings a bell or around there anyway
Posted 07 July 2007 - 07:56 PM
87. i will cross that bridge when i get to it
Posted 07 July 2007 - 07:58 PM
well your car is illegal without them and surely by us telling you that then you are now at that bridge and should cross it now?
what have you done with the holes left by removing the indicator?
Posted 07 July 2007 - 08:39 PM
i was all changed when i had the front end changed
