MG Midget SU's
19 replies to this topic
#16 Road Runner
Road Runner
  • 445 posts
  • Local Club: BMC
Posted 08 July 2007 - 07:45 PM
You will need a new maniflod as they are differant , the mini one is shorter and has a differant angle.
#17 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 08 July 2007 - 07:54 PM
you will fine the only differences (apart from the manifold) are the piston springs, needles, and possibly the dampers
And the float chamber spacers, as above. And the choke and throttle levers. And the carb spacer size. And the float lids. The comparison table doesn't list all the parts in the carb, only what's considered to be tuning parts. The basic build parts aren't in it. I've turned a couple of sets of Midget HS2s into Mini setups and it isn't hard. The parts required are pretty cheap. You must use a Mini manifold and carb spacers or you'll never fit them in behind the engine, you also have to use offset filters. You must correct the float angle or the car won't be tuneable. No a Mini doesn't break down on a hill but that's not the point, it's about the fuel level in the jet and is just as important as the float height (which also changes as you go up or down hill remember and that compensates). I've tried setting a car up with the wrong angle float chambers before I discovered that was the problem and it simply doesn't work.
#18 James_1
James_1
  • 253 posts
Posted 08 July 2007 - 08:52 PM
I'm glad I didn't get them then! I'll get some proper Mini ones. Nobody bid on the scruffy ones on eBay which finish tommorow, I'm bidding for them and I can't afford a lot!
Edited by James_1, 08 July 2007 - 08:52 PM.
#19 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 08 July 2007 - 09:33 PM
pm Smudger he has a couple of sets for sale that can be made into one good pair or refurb both and sell the second lot to recoup some costs
#20 GuamMini
GuamMini
  • 54 posts
  • Local Club: Guam Classics
Posted 24 November 2011 - 11:39 PM
too bad I posted the same question before I found this
