Clutch master cylinder.
16 replies to this topic
#16 mk=john
mk=john
  • 1,167 posts
  • Local Club: Milton Keynes Mini Club, Mini Cooper Register
Posted 15 July 2007 - 11:08 AM
To remove the split pin holding in the clevis pin can be a pain!! I kinow, but I found that having long nosed pliers helps a lot. After opening and straightening the split pin, I used the pliers to break off as much of it as I could/
After checking the clevis oin itself for wear, I then used an R-Clip (that is used to hold the body on to R/C cars), the clevis pin in place. This will be much easier to remove in the future!
#17 T.Dog
T.Dog
  • 35 posts
Posted 01 December 2013 - 07:47 PM
Just out of curiosity, would a bit of garden wire wrapped around and through the hole of the clevis pin do the job?
