What spark plugs for a 1380 sw5
16 replies to this topic
#1 tomkidd
tomkidd
  • 559 posts
Posted 12 July 2007 - 09:12 AM
Hi guys, just wondering what your personal opinions/suggestions for spark plugs are on a 1380 with an Sw5 cam in a fairly mild tune (105bhp)? Im currently running BPR8ES's?
#2 philc
philc
  • 839 posts
Posted 12 July 2007 - 09:31 AM
go with the BPRE7 they will do fine you will nto need to go any higher than that
#3 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 12 July 2007 - 01:34 PM
Blimey!! you were running with #8 plugs!! ;)
Im running with 6's with a compresion ratio of 11.2:1, id like to fit the 7s but not many people stock them and are order in. Though im not having any problems with the 6's, 6's being standard fitment :P
#4 Guest_mark clark_*
Guest_mark clark_*
  • Guests
Posted 12 July 2007 - 01:38 PM
my 1380 with a piper 255 is running on 7s. the last set i bought was from moss. not sure how many they have iin stock though
#5 tomkidd
tomkidd
  • 559 posts
Posted 12 July 2007 - 01:42 PM
MED told me to use BPR8ES and thats what I put in last time, they are 4 years old now though... but it still got 105 bhp on mini sports rollers at the minifinity shoot out. It does have the standard dizzy which is electronic
Edited by tomkidd, 12 July 2007 - 01:44 PM.
#6 Jammy
Jammy
  • 25,397 posts
Its all 6s or 7s! :P Either should do you fine. If you find that your plugs are sooting up quickly and your getting through them then upgrade to 7s. BP6/7ES for points ignition, BPR6/7ES for electronic ignition.
#7 m1n1
m1n1
  • 759 posts
  • Local Club: I'm unsociable
Posted 13 July 2007 - 09:24 PM
JUST bought a set of copper core NGK bp7es spark plugs from halfords. Used my trade card also and got the down from £8.99 to £3.50 for the set.
proper motor factors should stock them also. Partco etc..
#8 ginigwunkle
ginigwunkle
  • 2,018 posts
  • Local Club: sheffield mini club
Posted 11 October 2007 - 09:41 PM
is that rite bp R 7es for electronic?
ive got bp7es currently
is there a difference in performance/relliability?
#9 Sprocket
Sprocket
  • 7,266 posts
Posted 11 October 2007 - 09:56 PM
Yes, the resistance of the HT circuit is all wrong and your neighbours will be wondering why their tv has a fuzzy picture.
I looked at an MPi where the owner had fitted non Resistor plugs, after a long journy the engine started to missfire badly. The car ran fine after it was recovered and returned home. We put this down to the fact that the coil or the transisters in the ECU had overheated due to the higher current. Changed the plugs and it never happened again.
Your electronic ignition is a transistor system and will overheat just the same, also the reason you should never use a sports coil.
#10 ginigwunkle
ginigwunkle
  • 2,018 posts
Posted 11 October 2007 - 10:01 PM
aaaaaaaah thats why my tele dunt work when im running it outside.
also could explain why the car dies after motorway trips to the shows etc...
shall get them changed tomorrow then!!!
#11 Don't Panic
Don't Panic
  • 642 posts
Posted 11 October 2007 - 11:06 PM
Damn it! just put BP7ES plugs into my mini today!
Usually minispares is really good at giving you advice so you don't make mistakes like this :P
Edit: Just checked and the ones i took out were BP6ES :dontgetit:
Edited by Don't Panic, 11 October 2007 - 11:13 PM.
#12 blacktulip
blacktulip
  • 6,224 posts
Posted 12 October 2007 - 08:23 AM
if its just a road car then you dont need fancy plugs IMO.
#13 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 12 October 2007 - 08:27 AM
NGK BP6ES or Champion NY9's will usually do the trick
Edited by Retro_10s, 12 October 2007 - 08:27 AM.
#14 Jammy
Jammy
  • 25,397 posts
Posted 12 October 2007 - 09:29 AM
Its the engine that determines the plugs, not the type of driving you'll be doing.
#15 blacktulip
blacktulip
  • 6,224 posts
Posted 12 October 2007 - 11:36 AM
true although i thought it was down to rpm and heat? i would think a road car will not get hot enough to use other than bpr6es plugs? if you change your plugs let us know how they perform mate?
Edited by mikecmini, 12 October 2007 - 11:37 AM.
