Edited by mika, 14 July 2007 - 08:41 PM.
drive shaft help
mika
, Jul 14 2007 08:40 PM
2 replies to this topic
Posted 14 July 2007 - 08:40 PM
hi i am building a magure inspired spaceframe but with Zcars rear arms diff setup i have the ride hight at 4" and would like advice in if its better to run my drive shafts flat giving a wider rear width or run them with a slight angle and bring in my mounting points to that of z cars ie around the 50" MARK any help from you zcar masters would be good thanks
Posted 14 July 2007 - 09:47 PM
It's normal to run a touch of droop on the driveshafts, what engine are you using, that may dictate what height the diff sits at order for the chain to clear the gearchange mechanism
David
David
Posted 14 July 2007 - 10:17 PM
hi i hava at the moment a zx12 engine i will look at the gear shaft tomorrow thanks
