Right... havnt updated in ages because ive been so busy with work but im now aiming to get the mini on wheels at least by christmas
Ive put the suspension on hold now so i can continue finishing the rest of the restoration
Obviously im not goint to paint it in my mums driveway so after begging my mate Paul to lend me his trailer i got my uncle (another Paul) to tow it to his house for me where there is plenty of space, a big compressor and a welder
After my uncle gave me a quick lesson with the mig welder i got to work welding up all the holes i could find, there turned out to be alot more than i expected... the ones underneath needed the most attention
Once i had done the welding i finished off the underneath, i used underseal over the hammerite which worked well
I decided to paint the inside with hammerite too just to add abit more protection, first i took off the old tar like sound insulation off the floor with a heat gun, scraper and big wire brush, id be adding some better sound insulation later...
Then i got to practice for the first time with the paint gun...
It was fun if im honest
was messy though
The week after i got to work with the grinder, and after abit of dent filling, loads of sanding disks and two wire brush attatchments...
Next time i do this ill get some proper paint stripping discs... or better yet get it sandblasted, its alot more work than it looks to do it this way, the discs i used were also far too coarse and left a few marks, im going to need alot of primer
Anyway i rubbed it all down with some wet/dry to try and get it smoother (and to get rid of some rust that had appeared after i had left it bare a little too long) masked up the boot because i want it to remain black, and then i gave it the first layer of primer
Once ive got all the marks out (which could take a while) ill paint the top coat... ill let you guess what colour
then after that im going to stick a rebuilt 998cc in until i can get my 1293 turbo finished
All comments welcome let me know what you think, but do bear in mind this is my first ever restoration and im still learning
will update soon
Edited by Mini Mad James, 28 November 2007 - 09:41 PM.
