hey, went to drag wars on saturday and it was the first time the car had been running for a long peroid of time, didnt do any runs but had a tootle round the pits! only trouble was that when ticking over the oil pressure on the digidash would drop to around 5, but then when the engine was further up the revs oil pressure would increase to around the 60 mark. is this normal?? anyone else with an r1 and digidash getting similar readings?
thanks for any help, jacko299
oil pressure
jacko299
, Jul 17 2007 07:50 PM
7 replies to this topic
Posted 17 July 2007 - 07:50 PM
Posted 17 July 2007 - 08:21 PM
yeah mine drops to 8 psi when hot idleing
Posted 18 July 2007 - 06:50 PM
Yes, if you look at the engine specifications for the R1 this is perfectly normal and mine is the same. No worries.
by the way, why didnt you do any runs??
Edited by R1minimagic, 18 July 2007 - 06:51 PM.
Posted 18 July 2007 - 09:16 PM
thanks for the replies will have to re set the warnings for the digi dash to stop the OPA coming up when the pressure drops! well, we'd only finished roughly bolting everything together on the morning, so we didnt have any harnesses, and the brakes still have some air in somewhere! got to try and get it MOT'd and then get some runs in at mini in the park! did any of you go on sunday? saw a white z cars do a run, and there was another in the pits, then the huddersfield car came a bit later on.
Posted 19 July 2007 - 07:30 PM
What do you mean get some runs in?
Posted 20 July 2007 - 04:09 PM
mini in the park is at santa pod this year?? so hopefully will be able to take it down the drag strip
Posted 21 July 2007 - 10:42 AM
Ah ok, when is it?
Posted 21 July 2007 - 03:05 PM
19th of august, think there might be a section about it somehwhere, will you be going?? Mini in the park if thats worked think theres some info there
