The Brown Bomb - "accident 2010"
244 replies to this topic
#16 Guest_ratty_*
Guest_ratty_*
  • Guests
Posted 31 July 2007 - 06:23 PM
Day 15
The panels and big hole required to replace the A Post and inner wing
#17 corrado vr6
corrado vr6
  • 678 posts
Posted 01 August 2007 - 08:12 PM
blimey you have done all that in 15 days ive done less than that in a year but lookin bloomin good well done fella cheers for the pm
your makin it look to easy slow down have a cuppa!!
#18 annodomini2
annodomini2
  • 96 posts
Posted 02 August 2007 - 08:41 AM
Looking like this will be running in a few weeks.
You in the body repair trade? Just appears you're used to doing this with a lot of pace.
Good luck! :kiss:
#19 Guest_ratty_*
Guest_ratty_*
  • Guests
Posted 02 August 2007 - 08:45 AM
I work in I.T but I've had 7 minis over the past 18 years so I've learned how to take them apart :kiss:
#20 Guest_ratty_*
Guest_ratty_*
  • Guests
Posted 02 August 2007 - 04:02 PM
Day16 rain rain rain
So I put up the gazeebo to work under :D
The front is all screw on now, just got the final panel alignment to do before I fire up the welder :kiss:
Anyhoo on to the pics
Its a mini again :P
#21 lewis
lewis
  • 2,322 posts
  • Local Club: Mini Club Jersey
Posted 02 August 2007 - 08:25 PM
how the heck do you work so quickly!
that looks amazing, hats off to you :kiss:
#22 corrado vr6
corrado vr6
  • 678 posts
Posted 03 August 2007 - 09:55 AM
lookin good once again likin this project!!
Have you just screwed the inner wing on for now then built up the front end, then will you go round and weld the inner wing in place once you know all the gaps are right or did you weld it straight on?? just curious as ive gotta do this soon, but mine needs a fair bit more work than yours!!
with the wings etc what order did you put them on?? ie: bolt on the main front panel to the subframe then work your way up, or scuttle then wings etc?
carry on like this itll be done by the weekend!!
#23 Guest_ratty_*
Guest_ratty_*
  • Guests
Posted 03 August 2007 - 05:28 PM
I screwed everything together except the front panel which is also bolted to the sub frame. It took all day to adjust the gaps until I was happy, then I tacked the inner wing in place. Then I stripped the front apart again so I could weld the inner and door step into place
I've worked from scuttle down as I wanted to get the wing and A panel gaps perfect, then fit the bonnet and final adjust the front panel
No pictures today and no updates until next week as I have to go away this weekend
#24 Guest_ratty_*
Guest_ratty_*
  • Guests
Posted 11 August 2007 - 04:23 PM
Day 26
After not having any time this week thing have slowed down but I got the inner wing, bulkhead and scuttle done today
Edited by ratty, 11 August 2007 - 04:24 PM.
#25 MINIMON
MINIMON
  • 454 posts
Posted 11 August 2007 - 07:15 PM
wow tha is incredible mate, you dont hang around
#26 Guest_ratty_*
Guest_ratty_*
  • Guests
Posted 12 August 2007 - 03:38 PM
Day 27
N/S almost ready for A panel
Hole in O/S floor to deal with
Removed rear subframe and found more holes
Sheared off one N/S bolt, i'll weld a nut on to remove it but at least the heal board looks ok
The old subframe Mmmmm, remember this still has over 8 months MOT
#27 wilcooper
wilcooper
  • 1,197 posts
Posted 13 August 2007 - 04:45 PM
yeeesh :S
#28 stickolip
stickolip
  • 217 posts
Posted 13 August 2007 - 08:37 PM
sweet im loving it. i dont know if this has already asked or you have said. but you leaving it brown?
#29 Guest_ratty_*
Guest_ratty_*
  • Guests
Posted 14 August 2007 - 07:11 AM
Not sure what colour or style yet, as its for Mrs Rat she's in charge of all that and is useless at making a decision :D
#30 M44K TS
M44K TS
  • 3,104 posts
Posted 14 August 2007 - 06:25 PM
i wish the progress on mine was that fast!
excellent tuff fella, will be better than new once complete
